A thought on alcohol swabs. The alcohol does as much damage to the tissue as hydrogen peroxide, so if you can clean the wound with clean water, and just a bit of soap, that is best, otherwise the antiseptic is good. almost all of the antiseptics do at least some damage, so its a personal choice. I've noticed with myself that I heal faster than I used to, and I used to either hydrogen or alcohol all my cuts.
Cool kits so far guys!
I noticed that USB stick blt-2-drg, I carry one mostly for work, but I do have some personal info on it for ID purposes. Anyone else carry one with medical info and the like? some of them are tiny, and with a password protection you could carry a high res scan of your important papers.
Schmiddy, I've found that half of my experiences and training in regards to first aid, is that getting a good assessment is key. Most people rush, think the problem is worse than it is, or do things that are unnecessary. Most medical stuff is in the boo-boo category, so its nice to have the knowledge to treat things as best as you can, and the materials to make that easier. Lets say your buddy gets a nasty gash on his forehead, six hours from town, on the first night of an overnighter. He's got no concussion that you can tell, but is worried about a scar. you could clean things up, steri-strip it closed, (or use band-aids, butterflies or whatever) and call it a night. OR you could throw a gauze patch on it, race back to the trailhead, leave half your gear, get to an ER and then have the Doc either rip the bandage off and ablate the wound (more chance of scarring) maybe do stitches, maybe not, and the trip is ruined, and you left behind gear has wandered off in the time it takes to get back. Most first aid courses don't teach that kind of stuff, because they assume that you are either going to 911 it, or go straight to a doc (truth is, most of the Docs and Nurses I've worked with can't bandage worth a damn) There are quite a few good wilderness first aid guides around, that tell you not only how to do a procedure, but when it is warranted, and when it is not advised.
That said, first aid stuff gets bulky quick, and you need to balance how much you might need per wound, what wounds are likely, and how often can you re-stock the kit. Even my little boo-boo urban kit is bigger than a altoids tin, and that is just an EDC comfort kit. The back country kit could easily fill my Remora, if not more. for off-roading it should be bigger, with at least a decent sized burn kit. I guess that's why I don't do the altoids tin thing, as in my mind one band-aid isn't going to fix any problem that is anything to worry about. It is neat to get all the other gear as small as possible, something that I've been doing for quite some time now (you should have seen my early "survival" kits!) and I'm finding that there a minimums I don't like to go below. One skill set I know I should be working harder on is "no-kit" skills, but its proving to be challenging enough to even get out, never mind practice stuff.
As for the space blankets falling apart, yeah, the cheap ones will after a decade or so. The AMK ones seem to do pretty well (although if you spill tomato juice on them, it will corrode the metallic layer) carry whatever you like.
To each, his own, YMMV and such like that. My opinions are worth less than the sticker price!
