T
Twindog
"The best slicing knives have a bevel 5-7 thousands wide"
That parameter is not enough information. We can have a thick grind on something with a really obtuse edge angle that will have a bevel that width and it's not going to slice very good.
"Perfect, even bevel"
The guided system is not the only factor for a "perfect bevel" you are also at the mercy of how even the grind is, there are plenty of production knives that have uneven grinds that when you put them on a guided system one bevel will be wider than the other despite the fact that the same angle is used.
One can also have wider and thinner bevels on the same side depending on how even the bevel was ground which you can notice very quickly when you pull the edge back on a guided system to <15°dps
One can also see this with thicker bevels at the tip, especially if the grind doesn't have a distal taper towards the tip. Meanwhile, freehand can flow with the grind inconsistencies better if the goal is an even looking bevel width.
"Resetting the intial, factory-imperfect edge calls for a new bevel, not matching the imperfect one we bought"
This statement can be misconstrued that if you freehand you're not setting a new bevel. Well, nothing is stopping a freehand sharpener from pulling the edge back or making it more thick as needed.
Here are some other points I think are necessary to bring up.
1. You can sharpen a much wider range of tools and blades freehand then you can with a guided system.
Japanese single bevels, scandinavian Grinds yard tools, commercial kitchen appliances, etc
While there are specialized jigs everything adds up in time and money to have a special jig for everything.
2. Set up time and requirements.
Some of these different kinds of blades are not always compatible with certain guided systems. Guilded systems that use clamps can have quite a bit of fiddling depending on the knife and clamp used. Using angle cubes, taping blades up, etc also slows things down considerably. Often some folk opt to take their folding knives apart to sharpen. Not very convenient.
3. Using a guided system removes more steel to make a flatter bevel than a freehand convex one.
This also means it takes more time, especially with the smaller stones.
4. The small stones and working in small areas can make a kitchen knife profile wacky.
Recurving can be an issue since you can work an area too much with those tiny stones versus being able to flow with the entire profile on the stone and fix any profile issues.
If there is a recurve issue it can be extremely difficult to fix with a guided system and under minutes to fix freehand on a stone.
