Jim March
- Oct 7, 1998
Phil, glad to hear it's at least possible.
Let me say that my first "megafolder" was an 4.5" AlMar spearpoint lockback with Zytel grips. False edge for about 2", basic blade shape similar to a Mini Shrike. Good knife, I missed it when I lost it about six years ago. Graduated to the longer but less-durable 5.5" AlMar, then the Vaquero Grande came out.
So...I've been packin' these for a while.
>>1. Would you guys prefer this "Big Honkin' Folder" to have CUDA button or opening disc/stud? (No, you can't have both!)<<
Stud or disk. One detail, once you've got a lot of blade mass you're into "snapopen city". You need to allow for that in the toughness dept. and realize that "extra stuff" on the sides are not a good idea. You'll see why when we get to carry methods.
>>2. G10 for handle? Any other suggestions?<<
Fine. Make sure it's well contoured to avoid a "slip up" accident on a hard target stab, where instead of penetrating the tip jams up and your fingers slip up the edge. NOT good.
>>3. Kydex carry rig? Still need a pocket clip?<<
Forget the clip. What I suggest is a *horizontal* Kydex carry rig where about 1/3rd of the closed blade "sticks out" and can be quickly grabbed. This is THE fastest draw rig possible; I practice with my large AlMars by holding a section of newspaper at head height with my right hand, letting go, drawing and snapping with the SAME right hand and slashing the paper at around mid-thigh height. Note: I'm fairly tall, so that helps extend the fall time...but still, it's a great party trick. I can do that about 75% of the time, I also practice a slightly slower, more secure draw sequence for "real social work" if need be.
The same rig can also be optionally mounted as a shoulder rig, and I'd include the paracord and drawings for how to set that up.
You want the sheath to have "laceholes" and include paracord and instructions for setting it up on any belt width without extra bulging or "different rigs for different belts". Horizontal rigs dig in when you sit down unless they're done *right*.
>>4. ATS-34 for blade? Prefer CPM?<<
Heat-treat it right, ATS is OK. CPM420V would be *excellent* but not at $100 more. $50 maybe. Methinks we're building a "combat monster", daily hard-utility edgeholding isn't really the point?
>>5. Plain edge, 50/50 or full serrations?<<
If picking one, I'd say "mostly" plain, just an inch or so at the base serrated. 50/50 is too much serrations at this blade length class.
>>6. Choose ONE blade shape!<<
Spearpoint, with a false edge 3" at the top, *sharpenable* and hides entirely within the grip like the Gerber Applegate.
Line the tip right up with the thrusting force through the grip.
EMail me at jmarch@ricochet.net if you want pics of the 5.5" AlMar horizontal carry rig. It's in leather, which is also practical especially if *mixed* with a bit of Kydex. Or a Cordura/Kydex mix. My horizontal rig also doubles as a mini-maglight holder, so at work I just "quick switch items" without unbelting, etc. Pick the right flashlight companion you could do the same, maybe a SureFire or something? I was just lucky the AlMar and MiniMag were near-enough-identical OD to interchange.
Jim March
Jim March
