I was asking if you'd clarify this statement. Are you saying the only honesty about locks is in the framelock area? I don't get it.
I didn't write that, so I don't know.
I think there's a fair amount of evidence demonstrating that the Tri-Ad lock is one of the strongest on the market. As for being able to support 500+ pounds, I was told by a Spyderco rep that in their testing of the new model BBL on the Manix 2, the knife supported over 1000 points at the pivot, at which point the handle disintegrated, while the lock remained fine. That's pretty darn good to me. I haven't heard much in the way of claims about the compression lock, and to be honest, I am unsure why it's supposed to be stronger than a liner lock. The physics is very similar, and they're going to fail in the same way. I don't think the AXIS lock is going to be quite as strong as the Tri-Ad or BBL locks from the tests I've read about, but it still is a VERY strong lock, and by far the fastest of the three.
For the price it's really hard to beat a CS knife with the Tri-Ad lock, they make great user knives, strong and reliable.
Saying 'really hard' would be an understatement , they are just impossible to beat at their price range in terms of strength
That being said , in terms of absolute strength , regardless of price and\or weight , I definitely believe Benchmade have the ability to make an AXIS which will be AT LEAST just as strong as Tri-ad , it's all about the components
Settle down killer. Read a bit. The forces acting upon a compression lock are completely different than those acting on a liner lock, and in all reality a tri-ad lock has more in common with a compression lock than a liner lock does.First of all , saying the AXIS isn't as strong as the ball bearing lock is laughable
The AXIS is light years better , stronger and by far more proven and reliable lock
I really don't know what so called "tests" did you read , but I would LOVE to see them , please post them
Second , Spyderco can claim whatever they want , but so far they are refusing to back up their mouth with actual evidence , which is some really weak shit in my opinion
Compression lock isn't any stronger then well built and executed liner lock or frame locks (such as ZT) , and it is basically just a vulnerable to same issues and failures liner and frame lock can suffer from
I think there's only one extra moving part compared to a tri-ad. All folders have a blade and pivot. Stop pin, lock bar, spring - that's on the tri-ad. Axis has that and a second spring. I think BM only made one linerless axis model, and some of the CS models don't have them, but I don't think liners really complicate mechanisms. And the tri-ad also has a second pivot pin for the lock bar.I doubt the Axis lock could be made that strong, it's over complicated in design so the knife would have to be huge (HEAVY) to get that kind of strength out of it, it's a good lock, but it's not in the same league as the Tri-Ad.
250 lbs, 1000/41000 lbs at the pivot would translate to what at 4" from the pivot? I am curious but don't have the math.
250 lbs, 1000/4
if they tested one inch from the pivot. putting the load right above the pivot doesn't give a lever arm
someone should invent a knife for you guys, it would have to be large, very sharp great steel, and maybe ONE FRIGGIN SOLID PIECE TO BEGIN WITH!!! dumbass thread
No, it won't be quite so easy as dividing by four.
http://en.wikipedia.org/wiki/Pound-force
It's really going to depend on the ratio of the distance from the force exerted to the distance from the pivot to the device which is preventing the blade from closing (all things being the same).
he is talking about Spyderco testing, the rating is pretty simple, the load at one inch divided by the length of the blade. He was asking about the length along the handle, but it's the same idea to differentiate between light, medium, heavy, and very heavy duty (it may be a little higher depending on the knife, but the the handle is longer than the blade and VHD is at minimum 200 lbs per inch). They do this because the distances involved in lockbacks, liner lock, frame locks, compression locks, ball bearing locks, etc are all different, but they rate with one system.
If that's correct, an Espada would score 2400lbs at the pivot and still be competely functional...250 lbs, 1000/4
I think we can all agree that the Spartan is probably the strongest folder for the price.![]()
