Well hopefully I'll get gen2 arms
I should be good though with an angle cube either way correct?
Mine has the old arms, and I've not had any trouble. You just flip the arms around if you don't want to use the preset angles so that the lock screws ride on the side without the detents.
I typically use an angle cube, but every so often I'll do a quick edge using the divots. I just use the 100/200 stones on the primary bevel, then step the angle out a degree or two and switch to the 800/1K paddles and hit just the edge lightly (usually until I can see a fully-apexed microbevel with a 10x loupe), then strop. It's not a good-looking edge, and the performance probably suffers a bit for the rough finish on the main bevel, but it is very usable, and VERY quick.
And that doesn't even start to cover the multitude of waterstone options, aftermarket diamond plates, the merits of mono vs poly diamond, CBN versus diamond, stropping substrates and the relative grit of the substrate itself... Plus the increased magnification and methods of testing edges with that degree of refinement.
THEN you get into the guys who prefer a rougher finished edge for the 'bite' it adds to the slicing cut!
Just gets more and more interesting the farther down you go!![]()
Just thought I'd post that my WEPS came today and I'm loving it so far. My 800/1k stones and two strops are coming tomorrow. I have some .25 micron diamond spray and .125 micron cbn spray coming in and I'll be ordering a roo strop soon. I also have the paper from 1k-2.5k coming.
I'm debating if I need the additional sandpaper/stones or not or if I can get away with spending more time on the 5 micron strops as I found a propack 1 for under 400$
everytime you post my wallet cries a littleWell, my reasoning is that since it takes a while for the stones to break in completely, the paper with help refine the edge in the mean time. If you've been to Clay's website and viewed the forums, you have probably seen when leather is used, it burnishes the top layer of metal which sorta of flattens the deep grooves left in the steel. This works to our advantage until we get to the sub micron level where the leather's abrasive qualities actually show up on an other wise clean edge. That's why I'm getting the kangaroo strop as it doesn't have the same abrasive properties of leather.
I have the pro pack 1 and I get pretty nice mirror finishes if I want them by spending extra time on the 3.5 micron strops.
Just back off a degree and use very light pressure, your edge will polish up and convex slightly. Scary, sticky sharp edges will be the result. Just use an angle cube if you want your bevels perfectly symmetrical.
That being said, I just convexed my Tuff by hand with sand paper and a cheap mouse pad and I'm just as happy with the results, maybe more so.
Grrr not a fan of break inWell the 800/1k and both strops got here. So far I'm really having trouble getting a sharp edge. Probably a combination of the stones being so new and the burr not getting stropped off. Not even close to a mirror either lol.
Grrr not a fan of break in periodWell the 800/1k and both strops got here. So far I'm really having trouble getting a sharp edge. Probably a combination of the stones being so new and the burr not getting stropped off. Not even close to a mirror either lol.
