Interesting to see your technique. I've tried the "fold over" thing, but I think I used much less pressure. Perhaps I was too careful. From what I've read, straight razor guys use edge leading strokes on stones.
So this video was to demonstrate that you can use edge leading strokes on a variety of materials?
Yes. I fold the rolled/burr/wire quite agressively (listen to the sound & wood shaving). Even at 3 micron level, I was quite rough actually. The idea of folding is to eliminate weak apex that can't handle the folding-pressure (aka edge roll). So for 0.25 or 0.1micron and somehow still has burr/wire, I fold more gently.
... One thing I notice is that edge trailing on a firm stone seems to make the apex less uniform than going edge leading. Other thing is that stropping (at least with an abrasive) even on a surface as firm as a single sheet of paper wrapped around a stone, results in a large increase in apex uniformity"
HH, I don't understand. What is the difference then between edge trailing on a stone and stropping (edge trailing) on a sheet of paper with abrasive on a stone. Why would that make a difference?
And, one more thing, HeavyHanded - it is really about time that you make a video!!
I guess removing the wire edge is most important on the final stone, but how important is it on the earlier stones when progressing over, for example, three stones? Is it better to fold and cut it on each stone to avoid having it "ripped" off on the following stone?
It was a very dense thread, but man I really enjoyed your theoretical approach to sharpening.
Thank you very much, I'll see the video when I can have a little time.
keep on going,
Mateo.
Sometime I lulled into thinking that abrupt bevel shoulder transition is 'the' wedge and exactly where excess energy spent to thrush the blade forward in order for the apex to seperate matters. At the same time, I sing 'thin-behind-the-edge' song. So how high up in the blade the 'thin' should be?
Mora Classic, blade thickness ~2.2mm, striped painted with permanent marker.
Resistance/friction of contact areas erased marker from apex to the wedging-line where the blade is about 1.5mm thick.
hm, for cardboard (and perhaps other stiff materials) it seems that answer is the blade (usually at the spine) should be as thin as feasible, i.e. without compromise the blade integrity. Performance drop drastically as blade thickness increases.
My Opinel #9 easily out-cut this Mora, however the Mora's handle is more comfortable. I think a blade with 0.5-1mm thickness would excel on most indoor tasks.
Hello Connor - I use inline/lateral/sideway motion a lot, especially when I need a finer finish on the same stone. Similar to your approach (where to stroke), I rotate/turn the stone instead, which reduce dish in stone. I definitely will take up your offers of lending eyes to the machinist's handbooks. Please post - sharing your skills & curiousities would certainly help me & others to realize/know what we didn't know or even awared.I'm very loosely following all of this (I am learning and thinking about a lot of things, but feel I am not getting everything), but what about sharpening an edge inline? As in, moving the edge in a parallel motion sideways. I know this will prove to be harder on a waterstone due to wear, but an oilstone would work so long as you keep changing where you stroke. Also, I have machinist's handbooks available, so just shoot me a pm or post up here any questions you feel the book may have answers for.
Very good thread,
Connor
HH - excellent questions (+ good deductions):thumbup:I'm curious if you noticed any trends in the post testing blade strategies - did the greater wedging action of the Scandi 'protect' the cutting edge at all, or conversely did the decreased resistance overall allow the full convex to maintain apex geometry longer? There may be other benefits/penalties that are not immediately evident?
I've done a lousy job full convex the Mora using 1x30 50grit slack belt. Lost at least 0.5mm blade height and 1mm tip in the process. Later on, I'll reprofile it using diamond plates 140->220->400->etc..PS, your stripe pattern is similar to the one I used to apply when sharpening full convex on a hard stone - Sharpie only. I've gotten enough of a feel that I do it by looking at the grind pattern, but was a big help when I first gave it a try.
