HH how Long have you been studying the metallurgy side of steel? I would like to get as good as ou and others here some day.at least you have abandoned any attempt to appear like you understand anything being discussed
You referring to me? I understand perfectly. After reading every post here and deferring to my own personal experience with the steel, I have concluded that s30v is difficult to treat properly but if done correctly it makes for a decent knife steel. Not the best, certainly not the worst but decent.at least you have abandoned any attempt to appear like you understand anything being discussed
nah, the guy posting about fairy dust and magic shoesYou referring to me?
I dont fully understand how a blade can be stronger but not as tough. Seems like the two would coincide. Powder steels all also seem to aim for a more homogeneous structure or more uniform and without as many voids in the piece of steel right?
So it seems that powder steels performance can also be seen in being able to hold a thinner edge longer than other steels, not blanketing all steels, but as a goal. S30Vs toughness allows it to hold a stronger edge at say 30* inclusive versus a 440c edge at 30* inclusive.
The only thing I would add is that--when I put out a bunch of hard-earned dollars for S30V--how do I know that THAT PARTICULAR knife got the required perfect heat-treat to make it a decent knife????
And why should I gamble on it???
That's the salient issue that bothers a lot of people.
In the end, you have to go by the reputation of the maker and/or heat treater.
It's a shame BG42EDGE has to be rude and derail many threads of this nature. I've chipped my 420HC and not my S30V, but that doesn't cause me to champion a negative argument.
Handwrecker said:
As I showed earlier on this thread......the internet is awash with reports of S30V chipping and very, very few reports of 420HC chipping.
So your one report must be viewed in that perspective.
And you are confusing a little irony used to make a point with rudeness. A sense of humor is a wonderful thing.
probably the same with knives made from powdered metals. strong if used correctly. if accidentally dropped or abused they will chip very easily
Actually I've made the cut plenty of times with a considerably thicker Spyderco Para2 in CTS-20CP(that chipped it a little), I just need to use more force to do so. Since then I've figured out that the trick to cutting that thick cardboard would be to make one light cut outside to trace the line, then cut again along the line, but deeper. Basically cut layers at a time rather than all at once. No more issues since then:thumbup:.Its not a knock against the knife or steel. At that geometry and hardness, its possible that no steel would have made that cut without rolling, but it didn't chip. At any thicker geometry, you likely couldnt have made the cut at all. I know I've made cuts with a Schrade peanut that my BM TSEK just could not make. I was not phisically able to push the knife hard enough to make the cut.
420HC has no carbides to speak of, and it is the size and distribution of carbides which make PM alloys superior in toughness to non-PM, carbide containing, alloys.
420HC can go up to Rc 58 at best. S30V can be from Rc 57-62. I also don't understand your confusion with the fact that 420HC having little to no carbides naturally makes it tougher. S60V will chip more than S30V, S90V will chip more than S60V, and S125V will chip more than S90V.Handwrecker said:
Yes, absolutely, I have a few dozen knives that fit the description. Once I feel they are dull, I can bring back very sharp edge using diamond or CrO loaded strops(0.25-0.50micron), several times, then gradually progress to 3mic, 5 mic etc, until the edge needs more serious bevel work, when I take out sharpening stones.My powder steel knife is so hard and holds an edge so well it practically never gets dull...... but it sharpens up real easy when it does get dull.
Dude, what's up with you and 420HC anyway, it is as usual softer than CPM S30V and doesn't have carbide content S30V does. Chipping is not the only way edges dull, rolling is much more of a culprit.Uh-huh.......very impressive, very technical.......so that's why the internet is awash with reports of S30V chipping and very, very few reports of 420HC chipping?
