almost as good as a busse......hummm... that's impossible cause nothing comes close to a busse.
but........
any lower rc knife made in 440a steel will be quite good when it comes to not chipping the edge or breaking.
seriously i got some 440a choppers that can take a beating, and not break. the edges roll easily due to the lower rc hardening......but they are really tough.
... Yes, INFI is tough stuff. But it's also known--even amongst Busse enthusiasts, for not having the highest edge retention...
http://www.bladeforums.com/forums/showthread.php/487168-INFI-2770-pieces-of-hemp-rope-!!!
As a matter of fact, INFI edge-retention was a selling point, alongside its corrosion & impact resistance. It may not match some of the fine-grain high vanadium powder steels available today for toughness and edge-retention, but it evinces its properties at 60 Rc. It is NOT "spring heat treatment". Just sayin'.
As mentioned by Dan57, it would be nice to see the test replicated in a documentable manner. Are there CATRA scores available on it?
I'm not saying it's not high quality steel, nor that Busses themselves are at spring-level RC hardness. Just that softer heat treatment (vs. glassy hard) and thick (vs. thin) blade geometries are inherently going to be stronger...
...Again I just think that MOST (not ALL) of the extreme toughness comes from geometry.
Out of curiosity, has anyone ever done abusive testing on a thin INFI blade? I haven't exactly gone digging for it, so I have no idea, but would be interested to know.
That is simply not true there are plenty of knives that are just as tough as a Busse IN USE. On paper INFI may be tougher but in use I would put a Fehrman First Strike (CPM 3V) or a Swamp Rat Rodent 6 (52100) up aginst any INFI blade. Or if I wanted one stronger I would contact Big Chris here on the forums and have him make me something out of 1/2 inch thick CPM 3V and only heat it to 55-56 hrc.
And the tests people mention are widely known but you guys need to remember that a ESEE 4 did ALMOST just as well and its 3/16 inch thick 1095.
The rope test was performed live at BLADE. Yes, it was a stunt, but there were other knife companies present that either could not or would not attempt to replicate it at that time. What is agreed upon is a) it must be fine-grained to hold its edge like that, and b) the edge must have been quite coarse to keep cutting like that.
I too cannot find CATRA results to compare. The best I can find is Jim ranking it alongside 154CM at 61 Rc.
Softer = weaker for steel, unless you are concerned with impact toughness. INFI claims good edge retention with high impact toughness and easy resharpening even at 60 Rc, with some corrosion resistance as well. Those are all excellent attributes in ANY knife, chopper or slicer. Machete or scythe? *shrug* I don't know why they haven't made them. But here is a link to the famous Cliff Stamp Busse Basic 7 destruction testing: FFG from 0.25" down to ~0.040", ~17-dps. That is not overly thick, and it was compared to others knives in the same category: http://www.cliffstamp.com/knives/reviews/busse_basic.html
Noss beat on a "Skinny" ASH as well as a monster Battle Mistress, but I didn't read what the bevel thickness of either was...
While "extreme toughness" may come from low RC and thick geometry in some blades, it is not so for all. Brittle steel must be left softer to prevent apex degradation compared to tougher steel. Softer steel must be left thicker to prevent edge-rolling compared to harder steel. 60 Rc isn't all that soft and 17-dps isn't very thick. If it can perform as well or better than 154CM in edge retention while evincing much higher toughness at the same hardness, that is nothing to scoff at.
Why do people give high regard to certain custom makers using basic materials with little regard for aesthetics? Because of the performance of their product. If folks think there are masters of D2 or 52100 or CPM-3V, why not also here?
And why do folks assume that all claims about INFI are hyperbole without actually looking into it??
