are arkansas stones the best for sharpening?
if i use the black and the translucent stone will i have a razor edge?
do they cut every metal?
I can attest to that. I haven't yet tackled any of my knives on my waterstones, but I've sharpened plenty of wood chisels and hand-plane blades. I'm here to tell ya: There are few things more satisfying in life than finally learning to "feel the edge" on the stones and be able to get a good edge on a tool quickly, even from a badly-damaged edge.Learn to use bench stones freehand and you will find sharpening to be relaxing, maybe meditative, and even enjoyable.
Well, that's the thing, isn't it? It is difficult, or can be, until you get the hang of it.I also do not agree with the opinion of some that it is difficult. It does take some practice, but I do not think it is all that difficult given sufficient practice.
They work fine on old fashioned carbon steel, but are a trifle slow and not so effective on high tech steels or harder alloys (mohs hardness is about 5.5 or about that of window glass, and the shells are rounded rather than sharp and angular). The hard stones actually burnish more than cut, but can give a nice sharp polished edge if you're patient enough... since they are so tightly bonded they can produce an edge equivalent to the edge from a 5,000 grit waterstone though the actual particle size is closer to a 2,000 grit stone.
I have no doubt an edge pro will make a very sharp edge if done right. My problem with it and other angle holding systems is that I find them very mechanical and not enjoyable to me.
Learn to use bench stones freehand and you will find sharpening to be relaxing, maybe meditative, and even enjoyable. I also do not agree with the opinion of some that it is difficult. It does take some practice, but I do not think it is all that difficult given sufficient practice.
I recently had hard time reprofiling my D2 knife with arkansas stones. It took hours. I'm considering to get some aluminium oxide benchstones for reprofiling. I've used one at a shop last night and it was much faster and easier at reprofiling
are arkansas stones the best for sharpening? who uses these stones to inform me? if i use the black and the translucent stone will i have a razor edge? do they cut every metal? naturall stones or synthetic and ceramic?
You find it necessary to regularly flatten an 8000 waterstone? Wow, you must do a lot of sharpening.(I flatten the waterstone regularly and use a nagura stone to start the slurry)
I would say I get about a 10% sharper edge with the Arkansas, although the waterstone does leave a better polish. I am push cutting for sharpness testing so slicing aggression shouldnt come into play.
as I'm sure most of you know, generally the tool is stropped after the Arkansas, putting a fine polish on it.
Stropped on what media? So the comparison is between the buffing compound and the 8000 grit waterstone?
Ninjajoe, When you use your translucent Arkansas stones do you use oil or water or just go at it dry?
You find it necessary to regularly flatten an 8000 waterstone? Wow, you must do a lot of sharpening. I spent hour upon hour upon hour on my stones, learning to sharpen and (successfully) sharpening wood-working tool edges, and never once found it necessary to flatten my 8000 grit waterstone. I'm sure someday it'll be necessary, but still... "regularly," eh?
