“Knife sharpening was often given short shrift in music school but you can't make a good reed without a sharp knife, keenly sharp” “By and large knife sharpening is taught as a footnote”
This is interesting. It often seems that many essential teachings are missing from formal education.
We don’t have any shaving or paper cutting tests. We mostly go by sight, feel and how it works. We do test the edge on our thumbnail.
Maybe it would be helpful to introduce such tests to the reed making community. Its intresting to hear how much difference there is of opinion, It seems that some kind of comparative analysis, instead of subjective opinions, would help you determine the techniques that produce better results. Just recently I discovered when reading other posts here that the newspaper cutting test can be much more accurate than the way I was doing it, by seeing how far away you can cut from the point you are holding the paper. The string test Cliff uses seems to be pretty accurate too.
http://cablespeed.com/~sgelliott/blade_testing/html/testing_sharpness.html
It seems to me that you are in an ideal situation to study the effects of edge geometry, sharpening substrates, etc. Since you sharpen so much, and it seems to be a proffesion where pricision results are critical. It would seem that other reed makers are in the same situation, and it differs form woodworking as in, as far as I'm aware, there are fairly accepted angles and techniques there.
Then there is the question of teaching. When a student is having problems: is it the student the abrasives, the knife or what? What approach did you plan to take? What do you think is a good way to go with students that are not geometry savy?
When I teach, I usually just play by ear and adapt to what seems to be sinking in, I just set a general guideline and go from there. I was planning to present it similar to the way I was taught, the “take 90 degrees, split that, then split that again” technique. That way you can just eye it and get pretty good results without having to remember angles and what not. Also I would teach them how to recreate the factory bevel (the marker technique). I was not going to get too heavy into the different geometry, as I think I would have lost a lot of students in confusion. I was just going to mention that there were different angles, and they can affect performance, and to talk to me after class if they wanted to know more (of go over it in class if there was significant intrest). My goal was just to provide them with a simple technique that works most of the time. I was also going to use the 3M film for consistency’s sake, so I could more accurately isolate individual students problems and address them (also it fit the cost factor). As far as the knife, well there is not much I could do about that, but most of them did have moras so there could be some consistency there.
As a function of grit yes, but not in detail for type at similar grit. I actually don't have them. I would tend to assume what you would see dominate would be the difference in grit but it would be interesting to see to correlate edge retention to grit and see if the coefficients were the same.
This is purely speculation, but I would think that the shape of the abrasive, brought to my attention by yuzuha’s post, might play a role in edge retention. Here’s my thought; since (correct me if I’m wrong) dulling is a combined process of small metal pieces being abraded off by the material being cut, and also the metal of the edge flexing and fatiguing, the microscopic “shape” of the edge in profile, i.e. if there are small serrations / jagged edges on a microscopic level;
http://www.tzknives.com/edges.htm the shape and size of these ridges / serrations, as a product of the shape of the abrasive that cut them, might have an influence on how the metal is abraded off in use.
Now of course, this might be getting far too detailed for any practical variation in edge retention, as probably these ridges are abraded off fairly quickly, regardless of there shape. However, it has come to my mind also that “grit” size of different sharpening substrate does not necessarily directly correlate to the fineness of the atonable edge. For example, as stated earlier by yuzuha “since they are so tightly bonded (grit of Arkansas) they can produce an edge equivalent to the edge from a 5,000 grit waterstone though the actual particle size is closer to a 2,000 grit stone” and in my experience and annr’s for example, the finishing / sharpening “ability” of the Arkansas stones seems to improve with age, even though the size of the grit must remain constant.
Also consider the atonable edge produced by different grits and different substrates. For example, is the edge from ½ micron strop paste “four times” sharper than that of an 8000 grit (1.84 micron according to Shapton) waterstone? Or even more simplistically is the edge form an 8000 grit waterstone twice as sharp as the one form a 4000 grit? I realize that this is oversimplifying the effects of abrasives on steel and the dynamics of sharpening, and I probably am thinking of things to linearly, no doubt it is quite complex and there are many factors to consider. Henceforth should we look at sharpening substrates (as they relate to atonable edge, or edge durability) simply on the bases of grit size, like how everyone seems to be saying that there is no way an Arkansas stone could produce an edge equivalent to an 8000 grit waterstone (because the waterstone has a finer grit)?
My answer would be that different sharpening substrates abrade the steel differently, possibly in many complex ways, also depending on the steel, and not necessarily directly relating to grit size. It seems to me that grit size should be used as more of a general guideline than a steadfast and constant rule when dealing with the difference in substrates. Also consider that the grit size ratings vary quite a bit from different sources, Cliff stated that Arkansas are about 1000 grit, yuzna said it was 2000 but acted like 5000, in my experience the edge its more like 8000 or 10000 waterstone. Tools for working wood says .3 micron aluminum oxide (3M film) is equivalent to a 12000 grit waterstone, but shapton puts their 30000 grit diamond glass stone at .49 micron.
Yeah, lots in the early reviews as I did a lot of angle adjustment and then used the same finish. You tend to see large improvements because of the effect it has on cutting ability. For example if you use a relief grind on kitchen knives it increases the edge retention massively because it reduces the force you use during cutting which means less force of the blade on the cutting board which is one of the major sources of wear.
I’m very interested in this and I have begun to read more about it (long process looking through all those posts) but I am especially interested on what you said here about kitchen knives, as that’s a big part of what I sharpen. By relief angle you mean the secondary bevel? As in the one between the primary bevel of the blade (the one that goes form the spine to almost the edge) and the sharpening bevel? What degrees have you found most effective in kitchen cutlery?
Yeah , on the softer knives you have to increase the edge angle or it won't be stable and will roll, similar with harder use. Thinning the grind helps cutting ability but you have to leave enough metal to be stable. Once you have figured out the stable edge angle(s) then you adjust the primary grind down and see how much thickness is required. This will be different for each steel, how much so depends on the properties of the steel. You see a big difference between the 45 HRC machetes and the 60 HRC tool steel blades for example in how much steel is required.
a similar thing (than the thing I stated with the USMC) happened to my nimravus, chipping and such at lower angles. This could be due to the M2’s being somewhat brittle as others have stated. It would be useful, as you said, to compile this data to a more usable format, even including ideal angles for various steels and for various uses, etc. you seem to have put a lot of work into collecting this data.
For knives that just do cutting, no prying or impact work, the primary edge grind (the bevel you see) is about 4-6 degrees and less than 0.010" thick and the part that cuts (0.1 mm wide) about 6-10
So I’m clear about your classification, here your just talking about the edge bevels, not the main knife grind / bevel (as in, on a full flat grind, the bevel that goes from the spine to the sharpening bevel) and when you state thickness, it’s the thickness at the start of the bevel in cross section? That’s incredibly small! To get an edge that thin the main blade grind must be fairly thin too, I’m surprised that a knife that thin has the necessary rigidity to carve with. Does that edge last long? Your chopping angles are also fairly thin for what I would be comfortable with, don’t you have lateral flex of the edge when batoning through twisty woods?. Compared to your cross sections my knife looks like an axe, so I’m curious to know just how much more efficiently these super thin bevels cut? I’m not sure I would want to sacrifice the durability of my edge if the gain were not extremely dramatic, is it? When you say “0.050"/15” you mean 0.050” relating to the thickness at the start of the bevel and 15 being the bevel angel?
