- Jun 5, 2012
Yup not a bad knife with the materials and the price. I was able to acquire a second run production for under 120 shipped and I'm quite pleased with it. Titanium frame lock with a super thick stock VG-10 blade for under 120, how? Yea made in China of course..
All said its a good deal and looks and works well, ala lionsteel. My knife had all the previous issues cleared up regarding the off center scales, my only bad thing was the blade was off center by a hair. If I tightened up the pivot to where the blade was centered no way was it going to be opened with the thumbstud. I found that happy medium where the blade is off by about 1mm but opens good with no play in any direction. Mine did not come with a tool for the proprietary screw head on the other side of the pivot, but it did come with a torx bit for the scale screws. It didn't fit the pivot thankfully I have other bits that fit perfect. You can still adjust the pivot, like OP said, using pressure with your thumb on the proprietary side and a torx on the other. Worked fine for me with the several adjustments I went through to find that happy medium with the pivot.
Now opening the thing with the thumbstuds is another story. The arc, the radius from thumbstud to pivot, is pretty large so opening is not too easy the conventional way. I found that using the thumbstud to push forward and not outward worked fine for me, and ideally the forward push with a light wrist flick worked super! I got it to pop open nicely with just a tad bid of practice, it is different but you can find that sweet spot.
All in all I'm quite happy with it, not my edc (little heavy for that) but perfect for a coat pocket in my opinion. It's my weekend warrior knife...
