Ankerson
Knife and Computer Geek
- Nov 2, 2002
Here is the background information about the Bravo-1 from the man himself:
Yeah and I still doubt it even today.
It's been quite awhile since I read the original B1 posts. If I get a wild hair, I might go back and try to find the one about the retail distribution requirement. But I'm pretty sure that's why Busse wasn't considered. It sure as hell couldn't have been about the quality of Busse knives.They were saying some of the knives tested and Busse was supposed to be one of them, the whole thing was odd from the beginning.
They tested the knives themselves and the only two knives that passed after a couple of months of abusive use...were our Gameskeeper and a Fallkniven but I don't know the model.
Is this the part that is doubtful?:
Maybe Force Recon didn't test Busse or Fehrman knives.
If you want to really confirm or refute the whole Force Recon thing with the Bravo One I suggest you go to www.socnet.com and ask!
-Stan
Well whatever the reason was that the tested knife failed, it should not happen, period. Most companies have a thing called quality control. This should especially be true for a knife that is touted as "survival." Imagine you put this thing in your SHTF kit, the S REALLY Hs TF, and you're stuck with a bum knife. Oops, it was a lemon. Too bad.
I was actually pretty close to buying a Bravo 1 at one point due to the universal praise (some may say hype) it received. This was before the D-test was out. But what put me off was the tang:
So much material is removed inside the handle that it looks not much stronger than a stick tang. So I decided to get a Fallkniven A1 instead and haven't looked back.
If you really like the look, you can get BRKT customized Fallknivens at knivesshipfree. Yeah, an F1 is still more than a B1, but only 60$ or so.
Have you ever noticed that most Scrapyard knives are stick tangs?
They seem to be tougher than most full tangs.
That skeleton tang doesn't give up hardly any strength ... especially when the knife is used as intended.
Are the customized FK A1 and F1 balanced on the first finger like the B1?
I've also never understood how an unbreakable knife will help someone survive.
To me survival would be knowing your tools and trying to use them so they don't break.
If you have to use a knife of a design like this to the point of failure ... something is wrong.
But it does give up strength.
Good point. I guess not. My Kraton A1 is balanced just on the guard.
Let's assume this is your knife, and you have to build a shelter and a fire within 3 hours or you will freeze to death:
Does this help you understand?
Or you might be in a situation where you have to accomplish a certain task, with the tools at hand, or something bad happens.
I still don't get it.
Is that your picture?
That picture has been floating around for years hasn't it ?
I've owned several Carbon V Recon Scouts, Trail Masters and SRKs' .... I've beat on them ... haven't broke one and I think that's the only one I've seen broken.
Have you ?
If you are going to freeze to death in 3 hours you weren't prepared in more ways that your knife.
I've camped in the snow plenty of times and never battoned wood for the fire.
I used a saw.
So tell me .... where is the saw used to cut that log in the picture that the knife is stuck into?
That is also a really nice fire pit for that "survival" situation. :thumbup:
That picture didn't help your survival argument. lol
Yes. If you have to fight for your life, something went very wrong. That's why the last thing you need right now is a broken knife.
Yeah, I have a Laplander saw that I use to cut down the wood. I use my knife for splitting.
Seems that you think the knifetests.com test is valid ... I could be wrong though.
Watch these videos ..... http://knifetests.com/scrapyardscrapper6test.html
I'll go on record as saying that whomever wedged that Cold Steel into that big a$$ log was an idiot !![]()
