I have the same BelOMO 10x. Have had it for many years.
If you, or anyone else, is familiar with USB microscopes, would you please recommend a good power range for detailed knife edge examination?
Thank you!
Have you ever noticed how the old guys know stuff? Sometimes you don't listen to them and later on you figure out "Hey that old dude really was spot on. Why didn't I listen when he told me what to do?"
David Martin, is spot on here. A coarse DMT is not coarse enough to do real work. Apologies to Obsessed. If your edge is butter dull, a coarse DMT is going to take forever to reform the edge. Something closer to 100 grit is the ticket. A coarse Crystolon should work. I know the DMT XXC works. If you "don't like the feel of diamonds" then the DMT XXC might not be for you. The Barynox Manticore gets raves from a lot of people here too. It's very coarse.
What you may not realize is this: You do 90% or more of your grinding on the FIRST most COARSE stone you use. It's going to get all of the wear and tear. Ceramic stones like the Spydercos, or finer diamonds like the DMT EF and EEF just barely, barely get any wear at all. They will last forever and ever and ever. As long as they are used for finishing like they are intended.
Coarse stones are for shaping and forming the initial bevel. Medium, fine, (and beyond) stones are for polishing.
Your coarse stones might get replaced eventually. If you do enough grinding to make that necessary. Your medium and fine stones shouldn't get replaced ever. Unless you make the mistake of thinking that a medium or fine stone is for grinding. IN which case you can wear it out. In the process you will wear out your arms and make yourself very frustrated. Use the coarse stone. It's your friend.
Brian.
What is the real grain of Spyrderco or in other words natural grain? What material is it made of?My understanding is that the Spyderco Fine and Spyderco Ultrafine are the same stone, just finished differently.
What is the real grain of Spyderco or in other words natural grain? What material is it made of?
Brian, if I have only one coarse stone and I want it to cut very fast and to last, what it would be?
Using Silicon Carbide sandpaper, on top of glass, with water on the sandpaper, I rubbed the stone in a circular motion until it was flat. I scribbled all over it with pencil, and kept at it until every bit was white and the whole stone was totally flat
I tried pouring 60 grit silicon carbide on glass and rubbing the stone on it but it just dished the glass and started to convex my stone.
I tried an inexpensive 140 grit diamond flattening plate, and it got it flat, but left deep scratches.
Finally I tried the Silicon Carbide sandpaper and it worked great. I took that side to 220 grit, tried it, and then left it there.
On the other side, I started with 220 grit, and kept at it with that grit until that whole side was flat. I then used my Atoma 400 and smoothed that side out more, tested it, and then finished it with 600 grit which leaves it very smooth.
For now that's how I left it. It's now a dual stone...The course side cuts more aggressively than the fine side.
The hardness of alumina ceramics is nearly three times that of stainless steel; silicon carbide is more than four times harder than stainless steel. This extreme hardness is one of many unique properties that makes Fine Ceramics "super materials" for modern technology.
Strength - Hardness | Characteristics of Fine Ceramics | Fine ...
global.kyocera.com › fcworld › charact › strong › hard...
I thought that alumina ceramic in Spyderco can not be cut since the stone suppose to last forever. Is Silicon Carbide sandpaper harder them ceramic? If I use 220 grit sandpaper will I make my Spiderco 220 as well? Why people buy several stones if it is possible to condition any Spyderco stone to any grit?
I am sorry - I guess my questions as dull as my knives (at least at the moment before I learned on how to sharpen -LOL) but is it hard for me to do things without understanding how it works![]()
I got it, guys, but still can I use acid? I think acid should do the best job to remove metal completely while not affecting inert ceramics.
