- Feb 28, 2011
Pretty sure it's the easily breaking. I don't particularly care how good the heat treat or steel quality is in my survival knife if it breaks in normal use.So the heat treat? Steel quality?
Does it matter?So the heat treat? Steel quality?
I 100% agree. Something heavily marketed as survival knife with a name of survival icon on it should be damn near indestructible.Pretty sure it's the easily breaking. I don't particularly care how good the heat treat or steel quality is in my survival knife if it breaks in normal use.
Yes, the OP should reinvent the wheel when there is plenty of existing evidence to support his positionI’m not going to go watch a bunch of YouTube reviews. If someone thinks a knife is garbage, they should be able to explain why in 2-3 sentences.
Yeah, just Mora will actually hold an edge, and seems to be pretty sturdy for what it is.Probably an unpopular opinion but it is a cheap, entry level knife. I would put it up against the basic Mora or any other fixed blade you can buy at walmart, aside from the Buck.
And not claiming to be "ultimate"Yeah, just Mora will actually hold an edge, and seems to be pretty sturdy for what it is.
And is less than half the price (here in Europe).
The mora is definitely cheaper. I have not been impressed with their edge holding but it isnt terrible. i think the grind helps.Yeah, just Mora will actually hold an edge, and seems to be pretty sturdy for what it is.
Sorry, but hard disagree. From the same retailer, the Bear Grylls Ultimate knife is about $50 and a Mora is about $9. I also think the Mora is a much better design overall, that's proven to be surprisingly durable while still being exceedingly inexpensive, lightweight and compact. Or if you want something that's built more like the BG, you can get a Cold Steel SRK in SK-5 for a bit less than the Gerber, and it's insanely durable. Heck, you can get a Mora Bushcraft in orange for only a dollar or two more and get a much better knife with most of the same bells and whistles.Probably an unpopular opinion but it is a cheap, entry level knife. I would put it up against the basic Mora or any other fixed blade you can buy at walmart, aside from the Buck.
A few years ago I was on a camping trip and a fellow in the next spot over had a fixed blade BG and a folder. He said it was his second time out using it. I asked to see it and it was dull and thick behind the edge, the blade coating was coming off. Later he was batoning a 4 inch log that had a knot and the blade bent. He tried hammering it straight and it broke, the handle cracked in the process. His folder didn’t fare much better as it lost the pivot pin the next day. Both knives dulled quickly and he was very disappointed and I don’t blame him.So what exactly is wrong with the " blade steel, geometry, materials or design,"?
What would you have done to improve the knife?
For the record: I'm not defending Gerber: I'm just looking for a factual reason for the diatribe...
The BG is the knife you give to the teeneage outdoorsman that will abuse it and lose it.
It looks like the BG is discontinued but they were $30 when I looked at them. I havent seen a mora for $9 in quite a while. Last time I did, I bought a few.Sorry, but hard disagree. From the same retailer, the Bear Grylls Ultimate knife is about $50 and a Mora is about $9. I also think the Mora is a much better design overall, that's proven to be surprisingly durable while still being exceedingly inexpensive, lightweight and compact. Or if you want something that's built more like the BG, you can get a Cold Steel SRK in SK-5 for a bit less than the Gerber, and it's insanely durable. Heck, you can get a Mora Bushcraft in orange for only a dollar or two more and get a much better knife with most of the same bells and whistles.
@BladeHQ has the Basic 511 for right about $9 right now. The BG was out of stock because they're DCed, but I went with 'our price' on it.It looks like the BG is discontinued but they were $30 when I looked at them. I havent seen a mora for $9 in quite a while. Last time I did, I bought a few.
I agree if the price difference is as big as you say.
I still have the SRK in carbon V i bought as a kid in the late 80s. It took a serious beating but the sheath wasnt great.
Does it matter?
But since you asked - yes.
Cheap steel is fine with me, but this knife seems to be both soft (poor edge retention) AND it still seems to break readily (which is a HUGE problem for a SURVIVAL knife).
And the handle seems fragile.
And the tang seems weak.
I don’t have first hand experience with it so I can’t say any of this for certain, however with this many folks demonstrating that it’s a POS, I have no interest in even touching one.
Do you like the knives? How come?
A question should be asked: "What will you be using the knife for?"Friend asking for advice: “Im looking for a knife to take camping, and I have a $50 budget, what would you suggest?”
Would ANYONE here suggest a BG Gerber?
That’s probably all that needs to be said.
I don’t build a lot of log cabins when I go camping.A question should be asked: "What will you be using the knife for?"
Whittling marshmallow sticks; is a lot different than building a log cabin...
Agreed.Friend asking for advice: “Im looking for a knife to take camping, and I have a $50 budget, what would you suggest?”
