- May 24, 2011
Has anyone shot the Remington UMC 9mm ammo? I got an email with a pretty decent price and am thinking about ordering a case.
I get that stuff.
What do you want a SBR for? Does it DO anything useful for you, firearm-wise, or is it just desire for a curio?
You know how everyone always obeys the speed limit even when they know they won't get caught? It's like that.
except it's a federal level felony, goto jail, all that. t'ain't a joke. BATF* loves that shit, unless you paid the tax stamps...
i should advise anyone to never be seen applying a pistol with a wrist brace to the shoulder, or even a free cheek weld.
i've been led to believe that mounting anything that can be construed as a stock to a pistol is a bad juju nonono.
i would also advise people to revisit their posts (that means bighoss) and remove any suggestion that a shoulder is involved. cuz, batf*
seriously
As far as shouldering a pistol brace... I have no desire to be the test case but, when first announced, I felt that there was no way the BATF&E/Justice Dept. could win a case where "misuse" was construed to be a "redesign" as described in the letter declaring shouldering verboten. Seems that they are also a bit dubious themselves based on the recently leaked white paper.
"ATF has not made another NFA determination where a shooters use alone was deemed be a redesign of the product/firearm resulting in an NFA classification. This ruling has caused confusion and concern among firearm manufacturers, dealers, and consumers about the extent to which unintended use of a product may be a basis for NFA classification. To mitigate this confusion and concern, ATF could amend the determination letter to remove the language indicating that simple use of a product for a purpose other than intended by the manufacturer without additional proof or redesign may result in re-classification as an NFA weapon."
They are considering dropping the language from the determination letter, but the statement that that there have been no other determinations like this leads me to believe that any competent lawyer would argue this in defense. Given the low chance of successful prosecution, I'd like to think that it's unlikely for the Justice Dept to even try to make this case. That said, I still don't plan on being the test case...
Full text of the white paper is here:
http://www.thefirearmblog.com/blog/...d-the-white-paper-on-firearms-regulations.pdf
It's a good read. Shows that there are those in Government employ that practice common sense...at least in my opinion.
Edit: And all of this said, I bit the bullet (haha) and ponied up $200X5 for some SBR stamps on Form 1's. 300BLK pistol with a brace is fine with subsonic ammo, but not particularly pleasant with supers. So 300BLK SBR was needed for pig hunting. Also, the ladies complained about shooting the 9mm AR pistol with the brace, so a Glock version and Colt SMG magazine version were required. A real stock does work so much better for me, but YMMV.
I see you like the 762...
Are those both 300 BLK?
Not a big black rifle fan, but I do find that pig gun appealing.
best i can recall without looking it up, the 300blk was designed from the get go for a variety of things, without compromising too much on any of them. can run sub-sonic, so suppressor friendly. can run hotter for distance in a longer barrel (no suppressor obvious). works well in SBR configs.
now, if there was only a reasonable pistol versionprobably is, i'm just not aware of it.
probably my "next thing".
for PDW, i went with an AR57 some years ago, bit more practical than a PS90 i think, but the same magazines. 50 pews. nice cartridge. matching pistol for lols. very light combo. AR57 made an integrally suppressed system as well, badass but not worth $400 and paperwork, i'd rather have target range for plates
for amusement, the 22wmr varietal (i saw john wick), in cmr-30 and pmr-30 is a nice backpack carry, but not terrible serious. fun.
for right now bump in the night though, a browning 44mag lever action might be the first reach. we got bears and occasional crazy dogs. pairs nicely with the SW six inch.
shame there isn't a cheap .460 lever gunfun round that. 44 mag is my fav. hell, shame there isn't a good AR system for that.
Correct on the 300BLK. Supers, subs, suppressed, unsuppressed....no need to change buffer weights, springs, or anything else. Gas port sized to work with pistol length gas tube in any of the four combinations without a variable gas block or other tweaks.
Darnit! Now you've got me looking at AR57 uppers...just what I need!
I'm not 100% on this but I'm pretty sure 300blk is optimized in a 9" even in the supersonic loadings
there's a lot of interesting overlap among cartridges, new and old.
.30-30 and .357 run about the same pressures, and very similar bullet weights. The .30-30 case has only a modest amount more volume available for powder. With a long enough barrel, you can get the .357 pretty close to a .30-30 (at the muzzle). Or you can go heavy and push a 180gr bullet from the same case. The .300blk is interesting mainly because it fits in the AR platform, but the case volumes and bullet weights are all sorta similar. The Blackout's advantage is its higher allowed pressure and spitzer bullets for better downrange ballistics.
Of these three, the old .30-30 owns the top end, with 150gr@2300fps, 170gr@2100fps out of a 20" lever carbine. But it's going to be a full-size rifle.
The .357 probably covers the greatest range of weapons, from pistols to 18" lever carbines, and hitting hard within its range (lousy aerodynamics).
And the Blackout owns the combat platform, probably matching the .30-30's practical range due to better aerodynamics, even with the same bullet at a slower speed - but less energy.
So pick what's important to you... If you're handloading, you can pretty much make any one of those do MOST of the job of any of them, ballistically.
Good analysis. And toss in the 7.62X39mm at 123-125 grains running 2300-2400 fps if you want to shoot a commie gun. Ballistically in the same ballpark as well.
