- Jun 7, 2013
Chris "Anagarika";12794168 said:This is one of the best learning Q&A thread! If both of you don't mind, please link it into the sticky (Mag's one).
Martin,
Even for me, a lot of the advice here is a good reminder of the do and don'ts.
Thank you! :thumbup:
Jtsession,
Thank you for taking the tips to practice & ask further.
I recalled sometime back an OP that simply ask, then argue, and ask again, but never (deduction from the way he/she asked) try and put effort to learn. Sharpening needs to be experienced then thought of, not staying in pure theoritical realm.
Good luck in your journey. You'll find it challenging and rewarding with several A-HA moment![]()
Sure thing, and I'm glad that this is a positive influence! Thank you for your encouragement!
Rope is one, any job that will dull an edge quickly no matter what edge it has (no point in constantly sharpening to a higher level), applications that involve cutting fibrous, low density materials. I discovered at work through trial and error that a coarse edge lasted a lot longer cutting clay-coated heavy papers. Have to experiment a bit, but any time a more refined edge won't perform well at a task, or dulls quickly, you should be considering a change of strategy. Instead of more polishing, maybe more of a draw cut will sever the material in question with less pressure and less down time.
To me, a clean edge is one that's been formed well on the stones, and deburred to the limit of whatever abrasive was used to grind the edge. Some stropping on plain paper or hard leather to finish will bring it up a notch or two without eliminating the edge irregularities. These types of edges perform with less efficiency when used to press cut, so just need to be aware of the intended task. In general (IMHO), a medium grit edge in the 800-1200 range will work best across the widest variety, with more or less finish falling into a range where the edge has a specific purpose (chopping, carving, shaving on the one end - hard use, low pressure draw cutting on the other).
This thread got into the topic a bit more, I added some micrographs for visual comparison.
http://www.bladeforums.com/forums/s...th-edge-aggression!?highlight=edge+aggression
Oh, I see! That makes sense, as I'd heard that blade irregularities acted like serrations on coarser stones.
I ordered some DMT-3. It's diamond paste with 1, 3, and 6 microns to them. The strop that I'm getting is two-sided, with what's described as a "suede side" and a "smooth side." Any idea which two pastes I should apply and to which sides for maximum polish/push cutting sharpness? I've seen some people get mirror-finished edges like that, and it looks amazing!
Speaking of mirror finishes, is it possible to get one on the whole blade using only sandpaper, polishing by hand? Everywhere that I see info on mirror finishes online, people talk about applying them with buffing wheels and compound. I took the teflon finish off of my recon 1 with 220 grit sandpaper and some flitz, but the surface is heavily scratched. I was thinking about working up through 400/600/800/1200/1500/2000 grit sandpaper, then stropping the entire blade with the dmt-3 compounds to try to get it as close as possible, but I'm not sure what effect it would have.
Thanks again for all the help, mate
