Beginner to knife sharpening - a few questions
It's the aluminum oxide/arkansas stones combo. Does this mean you'd do 200/600/4k?
I'm not sure I follow what you mean about the shoulder recalibration bit - could you possibly go into depth on that a bit more?
Lastly, if I'm using the soft side of the leather strop, does this mean I should pick up a second strop in order to use more than one compound at once, once I begin working with compound?
Thanks so much!
That's the sequence. In all honesty, I'd consider picking up the King 800 or 1k to use with the 4k, and just use the 200 grit alumox stone for rough work. Not that the Arkansas stones aren't a good choice, but they might not compliment the 4k. In all reality, the 1000 grit Arkansas on your Tri hone should be in the neighborhood of the 4 waterstone as far as finish goes, so your two finishing stones should be comparable in terms of results.
By using the King 800 or 1k and following with the 4k you get a continuity of abrasives and the technique will flow a bit better. It will work OK the way you're intending anyway, but often you will get better results by using all one kind of abrasive in stages as it tends to give more predictable results. For a final finish, or a real coarse starting abrasive, not a big concern. Its in the middle part of the progression that you don't want to jump from abrasive to abrasive if it can be avoided.
The shoulder calibration is very simple but has to be done a few times to get the hang of it. On finishing stones, or anytime you're grinding and feel that you're "loosing touch" on the stone, the instinctive reaction is going to be elevating the spine to increase feedback, oftentimes without conscious action. Be aware of this and instead, lower the spine till you feel it lightly grinding the intersection of the shoulder and the bevel. Whether using a leading, trailing, or scrubbing (both) motion this will work. Don't hog away, just a few light passes - once you identify the difference, elevate the spine a small amount till you feel the feedback lessen/taper down. Now you know you're somewhere on the bevel and have given yourself a fresh tactile calibration and correct angle to hold the edge.
When starting out, you can actually work a few times from apex to shoulder to give yourself an idea of how convexed the bevel is becoming and to differentiate the feedback of the shoulder from the feedback of the apex- the apex feedback will be very similar to the shoulder but different enough to feel. On a convex edge you can do the same thing, just lower the spine till you know for sure you're not on the apex and slowly elevate the spine. As you feel it starting to catch, you know right where the apex is and where to concentrate your attention to shape the convex the way you want it.
As you start in with a polishing stone you should calibrate by finding the apex and the shoulder, and once located stay just off the shoulder. This is what I meant earlier when I suggested working from the shoulder toward the apex. Your new grind marks should advance from shoulder to apex as material is removed. This will keep your bevels more flat and at or just below the target angle you came off from the last stone.
We're starting to get into some "intermediate" freehanding principles here, go slow and use the coarse and medium stones until you feel like you have good control.
As for stropping, don't use the soft side unless the leather is at least as firm as pine. You must have a different strop for each compound.
Edit to add:
As you grind down from the shoulder, you'll eventually run into the apex and feedback will increase again compared to working the bevel flat. The flatter you make the bevel at each stage, the faster you'll get to the higher feedback zone where you're removing steel from the apex and generating a (smallest possible) burr. Another reason to get real good with the coarse stones - it will save a lot of time on the successive steps.
Got it! In this case, "Apex" refers to the point where both bevels meet in an edge, right?
What is the shoulder? I googled it to make sure I was on the same page, but all I could find was something saying that it's the front guard on hidden-tang blades. I think that you mean the "rear" side of the bevel, where the apex is the "front" side. Is this correct?
Yeah, that's it. The shoulder is the back end of the bevel. On a Scandi its way up the blade face, it doesn't exist on a full convex.
Chris "Anagarika";12808487 said:
Martin,
Thanks for reminder. I sometimes forget that and round off the apex. Appreciate the step by step.
Chris, I sometimes do too, or at least start to. "Snap out of it Man!", and then I'll lower the spine and remember to "listen" again with my fingertips. You can only rely on muscle memory so much.
Im trying to learn freehand sharpening. Yesterday I was experimenting on my Opinel with V edge and the result was awesome. I marked the edge with black marker and then I was trying angles.. After couple of minutes a was like a robot :thumbup:. Problem appeared when I tried to touch-up my Rat1 with microbevel. This bevel is so small that I cannot see if Im using the correct angle. Lot of people is like " I have no idea what angle my microbevel is, I just touch up and the result is good." Any idea how they do it?
When stropping with the DMT-3, how many passes should I make on each compound?
Keep it to a minimum to start, maybe 8-10 per side. I would be very leery of using them in a progression independent of stone work at each stage, unless the blade were a full convex or Scandi. Stropping involves a lot of trial and error - the backing one person is using isn't going be exactly like your backing, and that changes everything. The harder the backing, the more passes you can use and the more pressure variation the process can tolerate. Those compounds on a piece of oak could sharpen a flat bevel on your edge, on relatively soft leather it will round your cutting edge very rapidly if a lot of care isn't used.
Experiments in stropping are going to improve your stone work, as you'll likely have to go back and resharpen the edge often before you zero in on the better results...
Depending on how small it is, you might have to use a guide to be consistent. This could be a sharpmaker. This could be two or three coins on your stone, used as a height reference for the spine. You could build a sharpening ramp like one of our members designed.
If the bevel is really,really small, you're probably going to be cutting a new one anyway once it's damaged enough to need a touch up. This is a bit of a fuzzy zone for me, as I haven't spent much time with magnification examining microbevels. I *have* applied them though, and use angle guides most of the time, usually a sharpmaker.
Good luck,
Brian.
Great information here! Still, I'm about ready to give up and pay someone else to sharpen my blades. I can't seem to fix my very dull blades. The edge on the left (when holding the knife in front of you, blade down) almost looks rounded before it comes down to the edge...
