About 2,060 results (0.32 seconds)
Lol, its a knife issue. Not a brand issue for sure. Nobody escapes the claim.
Search Results
Web results
ZT uneven grind/edge at blade tip | BladeForums.com
https://www.bladeforums.com › ... › General Knife Discussion
Apr 27, 2015 - Fairly new to higher end knives so I had a question on a new ZT 0801 I picked up. The
blade tip is a bit
uneven, and I was wondering if that's ...
Is uneven blade edge grind normal?? | BladeForums.com
Feb 15, 2007 - ... curious if it is normal for a new knife to have such an
uneven blade grind. ... If that is true, then the edge thickness at the
tip may indeed be ...
uneven grind strikes again | BladeForums.com
Dec 5, 2013 - On one side the
grind ends 27mm from the
tip, on the other side it ends 22cm from the
tip. I'm tempted to return it for an exchange. What would ...
Help me fix the uneven edge angles on my dull benchmade ...
https://www.bladeforums.com › ... › Maintenance, Tinkering & Embellishment
Sep 16, 2009 - Help me fix the
uneven edge angles on my dull benchmade ... stones seem to be almost useless for the task of
grinding down shoulders. .... Using the
tip to open boxes and the rest of the
blade to break them down when ...
Uneven sharpening of blade edge | BladeForums.com
Nov 26, 2011 - I have a new Benchmade in m390 that has an
uneven edge from the factory. ... that I have almost a zero
grind on the front of the
blade and a wider bevel ... Not huge but enough that when you look at the
tip, it might be a 1 to 2 ...
Becker BK 2 Uneven Grind | BladeForums.com
Feb 2, 2011 - From
tip to end
grind is
uneven. Near the handle would be about 1 millimeter
grind but going towards
tip the
grind is about 2 millimeters.
para2 uneven grind??? | BladeForums.com
https://www.bladeforums.com › Forums › Manufacturer's Forums › Spyderco
Feb 24, 2014 - I just couldn't wait the 1-2 months for the black
blade digi camo so I ordered up a satin ... My sebenza had
uneven grind near
tip and heel too.
Rat 1 uneven blade grind | BladeForums.com
https://www.bladeforums.com › ... › Manufacturer's Forums › Ontario Knife Company
Feb 13, 2018 - ... inspecting it a little bit closer I noticed that the
blade grind was very
uneven. ... I've got more than a few 100+ knives that are like that at the
tip.
Uneven blade grinds | BladeForums.com
https://www.bladeforums.com › Forums › Archives › Blade Discussion Forum Archive
Jun 5, 2001 - Basically good fit and finish, EXCEPT the
blade grinds don't come together at the
tip in the expected V shape. Now, before anyone thinks I'm ...
Tips for correcting uneven edge angles? | BladeForums.com
Mar 30, 2016 - Even an
uneven swedge
grind can cause differing
tip thicknesses. If the
blade is well ground and it is just the edge needing attention I would ...
Uneven grind on Delica ZDP ? | BladeForums.com
Feb 21, 2011 - Great knife, but the
grinding on it is
uneven. ... Support
BladeForums! .... The saber
grind line near the
tip of mine is just a bit off on one side.
Mar 22, 2017 - The
tip isn't bent, it's​ just the angle of the picture. But if you look close you can see how
uneven the
grind is. I'm​ fairly new to ...
Ontario Kukri - uneven blade grind (not edge) | BladeForums.com
Feb 17, 2015 - Ontario Kukri -
uneven blade grind (not edge). Discussion in 'Ontario .... and the bevel near the
tip on the left side varies wildly . Feb 20 ...
[URL='https://www.bladeforums.com/threads/uneven-bevel.812048.
