You caught a mistake. I meant Chrome. I would love to see 13% carbon.I'm going to have to disagree with you on this one. High Carbon steel is 0.6% to 1.5% carbon. 1095 high carbon steel is 0.95%. Even the toughest tool steels, don't have a carbon content above 1.5%. If someone was to actually mix 13% carbon with iron, is suspect it would crumble. I'm not a metallurgist, but I don't think it could be feasible.
No worries. I kind of thought that was what you meant. The minimum chromium to be considered stainless is a matter of debate. I've seen different steel nerds quote different percentages. But, I believe when the carbon content is increase, the chromium content has to be increased as well. I'm not 100% sure of that, but it seems logical.You caught a mistake. I meant Chrome. I would love to see 13% carbon.![]()
I have an old one that I like. It spends most of the time in gear bag for trips to my remote cabin.Sorry if I'm keeping and old thread going. I wanted to see what people think of the Ontario Bushcraft Woodsman. It's a beastly full tang survival knife, with near Bowie blade length. It used to be made from 5160, but OKC switched it to 420HC at some point. I can still buy either model. On a blade that thick, 420HC isn't a bad option. Heck, my SZCO High Carbon Bowie can't take a ton of hard abuse, and keep going. It's allegedly 420HC, but I doubt it. It rusts too easily. I'm not sure of the grind type on the Ontario Bushcraft Woodsman. It looks like either a saber/convex grind, or a full flat grind. I wouldn't mind that knife, if the 420HC is properly heat treated.
That's good to know. I'm guessing you have the 5160 version.I have an old one that I like. It spends most of the time in gear bag for trips to my remote cabin.
I've heard conflicting reports. Some say it's hollow, some say it's full flat. I'm guessing the new 420HC might be full flat, while the 5160 version is hollow. I'll have to do some more research. The well known knife retailer that was listing the specs, said it has a hollow grind, but it also said it was 0.19" thick, when it's clearly nearer to a 0.25" spine thickness.
Thank you for the confirmation. That's what it looked like to me.The Woodsman is flat ground.
I have both versions; both are flat.
Thank you very much. I don't buy hollow ground survival knives. Much appreciated.The Woodsman is flat ground.
IMO, Gransfors Bruks are a bit overpriced for what they are. Fiskars makes very good axes, at least according to the reviews. They have a lifetime warranty, although that probably won't help in a survival situation.A bit off topic but the Gransfors Bruks Small Forest came up earlier in the thread. I have it and it’s a beautiful axe but take a look at the Hultafors Ekelund Hunting axe which I also own. Very similar axe at half the price (if you order it from a certain store in Helsinki) and it’s every bit as good as the Gransfors. The Hultafors is slightly beefier than the GB Small Forest Axe but that’s a bonus in this case. I consider this my best axe purchase (value-wise) to date. Pic below shows the Ekelund next to the Small Forest Axe
View attachment 2510913View attachment 2510918
