Best work around the house/yard folder for under $100
Have to second/third/etc. the Rat1 suggestions. Great knife for the price. Would be a good knife for twice the price.
Absolutely, I love the Rat 1 and 2. Both really amazing quality knives for right around $30, smooth action, very strong lockup with no play, quality grip materials and fit/finish, blade has a nice consistent factory edge bevel that will shave arm hair. If somebody wants a good-size, all purpose economical folder, one of these should be a serious option.
Ontario Rat 1, Buck 110, or Buck Vantage Pro in S30v. All strong dependable blades that are high on the value scale.
All these, and one thing I forgot to call out earlier when I recommended the Vantage Pro as well: OP said he likes flippers, this is a flipper.
Agreed!
I have recently replaced my old, much used, Rat1 for a new Rat1. It was a dreadful story of alcohol, the desire to take apart my Rat1 because I wanted to and had never needed to, and a drunken mix up involving similar looking tubes of lube and glue. It wasn’t my fault, honest...
+1 on the Buck Vantage Pro. Love mine!
I've become a massive fan of the CS broken skull for around the house and yard. It's a lot of blade in a small and very easy to pocket package with a good hard use steel and lock. I liked it enough I grabbed a 2nd and plan to use it as a folder for hiking/camping/bushcraft as another option aside my fixed blade(s).
I also like my D2 griptilian I found on the exchange but the mini-grip with a modified sheepsfoot is still my favorite modern folder EDC and I like it for around the house. The mini is a bit small for around the yard as the handle doesn't lend itself well to harder cutting like clearing vines or small branches from the landscaping.
I never cared for the "GO" directive. It reminds me of someone distasteful.
No flames. You have good suggestions.
Ontario Rat 1. $28-30 with AUS steel, solid design, larger size than the much renowned edc rat 2.
edit: you can buy 3 for $100 btw. place strategically around the house / garage and never be very far away from a good knife
RAT-1s are the modern day Buck 110s ... great knife/great value.
Pacific Salt SE.
+1 on the Pacific Salt SE knives, not in the budget beater price stratum - but great knives in their own right.
I'm with you on the sheepsfoot mini, but for clearing vines and small limbs, nothing I've got does it better than a hawkbill serrated edge, like the Spyderco Tasman Salt.
Agreed!
To be honest, the spyderco tenacious is a tough little knife. Its $50 too!
I just have a really hard time with a US company outsourcing to China and charging $60 for it, I’m sure the tenacious is a fine knife but c’mon. I feel the same about the RAT-1 and it’s Taiwanese origin. I know this type of overseas outsourcing is common as pretty much every mainstream knife manufacturer has done it now and I’m being a little “old fashioned” but I can’t help it.
The Buck vantage is USA-made. So are Buck’s spitfire and and Bantam.
The Bench mini grip can be had in the OPs price range. A fantastic USA-made tool.
Kershaw has the Leek and the Link and Blur and several good USA originating knives in the $30-$100 range.
Point is there a many good blades that can be had from our own work force in the sub-$100 range.
If I’m going to buy a made-in-China beater knife I don’t want to pay a dime over twenty bucks for it.
$60!...who do they think....?!?!???
I know where you’re coming from, even though I refer to a certain metal as aluminium..!
I collect mainly USA production knives, so for reasons distinct from yours I also prefer to see ‘made in the USA’ on the box. I would, however, draw a sharp distinction between China and Taiwan, as do the Taiwanese - much to the consternation of Beijing.
As you say, many others have outsourced and continue to do so; I think an Al Mar Sere 2000, for example, is made in Japan, and it’s a wee bit more than twenty bucks. ;)
The Rat-1 is worth the asking price, regardless of the country of origin. But yeah, having ‘Ontario’ emblazoned on the same piece of steel that reads ‘Taiwan’ does rankle somewhat.
Depends, if the vines are growing on something like a fence a machete is no good.
Yep, It does. I would honestly be using a pruner (shears) for the most part unless the vines are really out of control. I like clean cuts on limbs too and you often don't get that with a machete or knife. But even that choice depends on the location. Everything depends.
+1 on PM2 and both CS options. Plus a couple more:
Buck Vantage Pro large (s30v)
Ontario Rat 1 (Aus-8)
Agree with these choices, but why not get the Rat1 with D2 steel?
Also look at the Cold Steel American Lawman. And the Griptilian is a fine work knife.
Don't want to derail too much, I have pruners and if I'm only looking to cleanup branches and vines such things then that's what I go for. Machete isn't going to happen since the vines are tied up in trees. Usually, the scenario is a vine that is wrapped around a tree trunk that constricts and eventually kills the tree so I cut it off at the base and let it die on the tree. If the vine is large I'll start trying to pull it out. I carry the knife around with me when I mow (push) and cut the vines as I come across them so convenience of carry is a consideration.
Hawkbill would be a good choice for this type of work if that's what the OP is doing. I had a farmer jack GEC for a while that worked okay but the longer blade was preferential.
Don't forget to look in to fixed blades. A sheathed fixed blade is easier to deploy and put back than a locking folder. Laws regarding carry probably won't apply on your own property, and you're not going to get weird looks at home (no more than normal, anyway).
