I have been trying to post on this thread for over an hour – embarrassing how many attempts and embarrassing frustration about it as well, but I have been having SERIOUS issues posting on this thread – yet no problems posting on a couple of other threads ???) So, I “finally” went to service and support and saw where another person seemed to be having the same issues I was having. He guessed that size of post might be a problem, cut the post into smaller pieces and it worked. So, here goes my attempt to “piece together” my attempts to post what is now a bit old…
…….. Anyway:
LVC is pretty well all over this one! Although, I doubt weight is a factor in Jerry's decision. 3 solid pins vs. 3 hollow pins probably amounts to a about .25 ounce difference at most and probably less in over-all weight. I have not seen any pattern to indicate Jerry has that sort of concern over either handle weight or over-all weight. Jerry seems to LIKE "FATTY" knives. Beefy and solid!
Big solid pins might "Seem" beefier and more solid, but they are NOT more "Secure"!
Big Solid pins would resist sheering much better, but they are NOT as good as "Flared" hollow pins over-all. As LVC said: Hollow pins "actively hug the scales". Solid pins are not flared and do not actively grip the scales other than a bit of friction if tight enough. The only way to make solid pins stick and hold well is with epoxy. Epoxy works VERY well, but is a PITA to remove the scales if they need to be replaced. If using epoxy, hollow tubes still win in the event the epoxy fails.
Hollow pins are probably a bit cheaper and a bit easier and faster to install in production (????), but I doubt that little bit of extra savings amounts to much in regards to Jerry's reasoning.
Sure the hollow pins can be "slightly" moved or develop a bit of wiggle if beat on to extremes, they are just a bit more prone to give "a little" if extremely abused. But, if a hollow pin gives a little, it is still pretty darn attached and secure. - If you know how, a loose hollow tube could even be peened back to center and secure if needed.
But, once a solid pin becomes loose, it is DONE! You have to completely remove the rest of the pins to fix the one or more that failed - so competely rebuild the scales. Further, if a hollow tube fails, you don't have to resize the hole. Just flare in a new hollow tube. If a solid pin becomes loose, a replacement pin isn't likely to fit right anymore and may new a "slightly" larger pin, might need redrilled scales and tang, etc., etc. complications.
