Jerry.. Just use a Hammer Lock set up.Have a solid pin inside of a tube.. HA HA!!!
There ya go.. Pins and tubes done..
Now,, For that little tip i would like the NMFBM.
Frosted with Black Paper.
Hey, iam a givin guy!!! HA HA!!!!!!!!!!!!
I thought the reason for tubes was a simple one.
Pins could break leaving you with a damaged and possible un-usable knife.
With fasteners, they will bend before breaking, leaving you with a usable knife. Very important if your way out, and can't get to another knife at the time.
Why don't Busse's have 'em?
Hopefully Jerry can answer, but it's always kind of confused me as to why they would stick with the hollow tubes that can potentially get knocked loose while batoning.
Considering the toughness of the knives I would expect something more along the lines of a 1/2" steel plug. I realize the tube pin system probably makes handle assembly a breeze, but it would be cool to have solid pins to add a little more assurance that the handle isn't going to go wobbly after a bad stroke with the baton.
If solid pins wouldn't work with the current system, maybe just doubling the tube wall thickness would?
Anyone else feel the same way? Or maybe you have beat the crap out of your tube pin handle and it's walked away laughing.
Interesting. Hadn't heard that before. Wonder exactly how that works?
AFAIK, It's been a practice with custom makers with hidden tangs forever.
Basically, the top part of the pin is "peened" with a punch and hammer to flare the top of the pin so that it actually applies force to hold the slabs on similar to the tube fastener. Usually, you see the dimples etc in the pin. THe ones Busse did are flat so I guess that got sanded off when the scales where shaped.
tell em Big ManKeep em straight!
Although, its not that we dont like that kinda stuff.
The good lord said, " Everything in moderation."
THere's just a lot of professionals here participating, and having that inadvertently pop up on screen is potentially a big problem with either the Boss or the wife
There's a time and place for everything, but this definitely aint the place for pics.
Gentle Enuendo's done properly can be laughed at, or ignored without causing too much trouble IMHO.:thumbup:
but this aint my house and I dont make the rules. I just make sure that I dont make the list........ again.
