Taboo + stud-lock + YXR7 blade + TiNC polished coating on blade and handle.
JYDII + same...
Thanks, Vassili.
That works too.
+1
JYDII + same...
Thanks, Vassili.
I am thinking the taboo with an exotic steel blade that is boron coated with a Ti or boron coated steel handle with carbon fiber inserts.
Ok, I have been thinking and drawing up designs on paper more, and I think that a Spec Bump with the AO On/Off switch, ZDP-189 blade, an integral frame lock, and a finger hole like a karambit.
A ZDP-189 Cyclone with a karambit finger hole would be awesome as well.
The blade forum knife will be based on a design that is already being made or is in progress. No changes to existing blade shapes. Sorry.
And, the Forum knife is going to be a Taboo! Nothing else!
hello mcfly-go back to the beginning-i am the deciderer![]()
so i think the first thing i should come up with is blade steel-i can decide the knife design later -
i really think the damascus kershaw does is some of the best ive seen-the etch just stands out -
so the blade will be damascus wire cut with a sg2 edge-hows that sound for starters
i would use a dovetail cut instead of that wave one-and on a wide blade like the mini cyclone i think it would work great
Well, I see you all are really narrowing it down. At this rate you all should have a knife dialed in sometime in 2009.
OK ok....we all just had a vote in the back and " we " decided on the composite Melee with a Ti frame lock.![]()
