We just finished a seminar, our student Mark Reich tested an experimental 52100 blade I forged and edge quenched. the test blade measured 3/16 thick, 1 1/8 spine to edge and 4 1/4 inches long. First came the edge flex test, 10 edge flexes, no chip, then cut - 150 cuts on tough hemp rope and still shaved hair, obviously would have cut more. Went to the post vice where we attached a torque wrench to her and it took about 70 foot pounds of torque to flex the blade to 90, then back the other way and again 70 foot pounds to almost 90 when the edge cracked. The crack extended straight up from the edge toward the spine for about 1/4 of an inch when it split and ran from ricasso to tip. The split or Y occurred when when it started into thee soft steel. We then straightened the blade and it could still be used.
That was tremendous pressure required to flex about 2" of the blade as the front third as in the vice and the back 1" was held by the clamp for the torque wrench.
The blade was 52100, rate of reduction by forging about 96% all low temp forging.
This is what is possible with the differentially edge hardened blade, and the results are repeatable. Each seminar has its own experimental blade that is developed as an example for the student. While each blade is a special experiment in its own right, not one has failed catastrophically in the 9 years we have been teaching differential hardening along with our forging technique. There is no magic, no secrets and we will share with anyone who want to know.
The methods have been slowly developed over the last 30 years, 100's of blades have been tested to destruction. Three metallurgists have worked with us and many blade smiths have worked on the development of what we do. I cannot tell you what is best for your blades, I can only say what we do and what the blades are for.
