Whuff. Yes, to some extent many steels will perform somewhat comparably if heat treated well in a variety of different tasks. But it really comes down to what your quotidian uses might be (sorry, just got finished teaching an SAT class, couldn't resist). If they're just slicing open packing tape for a couple boxes here and there, or opening the occasional envelope, etc, then yes, most steels will probably work fine for you. Then again, you're not really challenging the knife. If you're expecting to be able to chop or baton wood, or worse, pry at stuff, and also expect it to still slice and dice with the best of them, well, you've got another think coming if you think all steels are created equal. For any kind of heavy task, your 440 steels may break where other steels will still be going strong.
Do you think you can just take your 1085 knife out and use it regularly on the ocean?
The simple fact of the matter is that different steels are better, often quite a bit so, at different applications. Some are very well rounded at a LOT of applications. Some are specialized for certain applications. Steel type DOES matter, although what you choose depends on your applications.
I think it's great that 440C is working for your applications and needs. That doesn't mean it will work for everyone, and you'd do well to consider that other people don't use their knives in the same way that you do.
And as to Tim's argument about if I can afford to buy something that's only marginally better... well, it depends on whether I need it. Would I buy a Lambourghini if I could afford it, considering that all I do is drive from point A to point B? Not likely. I'll stick to my Subaru. Cheap and reliable, and gets me from point A to point B with a minimum of fuss (and a minimum of getting pulled over by the cops for going 2 mph over the speed limit). Blowing your wad on things that you can afford, but don't need, when there's something else that gets the job done at a much better price point is a great way to end up going bankrupt. I buy only the things that I really need or want. If 440C does well for the OP, I for one don't think he should be forced to try a different steel.
On a completely unrelated note, when did it become cool to call people "brah"? I mean, basically, we just saw one dude call another dude a name that's frighteningly similar to that of a ladies undergarment, and not even intend it to be an insult. I just find that weird. /digression.
