- Mar 1, 2010
Well, even if the OP just uses them for show, I bet that he can still tell steels apart.
Just look at the tang stamp...
I also work in a warehouse, cutting pallet ties, breaking down tons of cardboard, even cutting some carpet for samples
normally I stick with a knife for a while and trade it out every so often to see how another one holds up.
Normally I edc a case carbon cv model knife, which works pretty good
but i am not going to lie, my rough rider barlow with 440A is one of my best cutters. Perhaps I havent stuck with it long enough to see the difference over time. But at the end of the day its stays sharper than anything else after comparable use. I admit to being rather surprised by this myself, but in light of this conversation it makes me wonder.
i dont have any super steels, so perhaps i just dont know what I am missing, but i have knives
420hc (buck)
440 (rough rider)
Aus8 (dozier folding hunter, perhaps the worst performing knife i have, at least in this application)
whatever steel Victorinox uses (i have no idea, inox)
1095 (old school old timer)
case CV (my usual, just cause i like it)
perhaps s30v or 01 or some other super steel would outperform any and all of these, but these all work for my purposes (i certainly do alot more than open letters or cut fruit)
i wonder, just how hard are you using your knives when folks say things like, it becomes more apparent with use. I think in my case, i prefer traditional slipjoints and they tend to be thin with good blade geometry and maybe that's why they are working so well for me, and they are easy to sharpen if necessary (usually because i slip and the edge rubs up against ceramic or porcelain which we deal with alot)
*shrugs*
just my 2 cents
Yes, thin angles, and edge finish depending on the intended job. It all plays role and pays off hugely if chosen/done correctly. Otherwise, dull supersteel is just as dull as 420 or whatever.Do you mean, taking " super " steels to lower angles taking advantage of composition ect? Seems like I read one of your articles about that.
Good input! Traditionals usually have excellent geometry, and yeah, that's what does the cutting. The steels and heat treat allow that geometry to be optimized greatly. For example, your 440A barlow is probably a very thin flat grind. For the uses you are describing, it's a great geometry for what you are doing.lol i even mentioned that the traditionals tended to have good blade geometry
i guess that was a roundabout way of saying, for someone like me who uses his knives pretty regularly, i havent really felt understeeled EVEN with 440A
but i did also mention the knives i use with more pedestrian steels might be better with some supersteel and i just have no idea *shrugs*
just sharing my experience
For example, if you were able to get the exact same knive in a "supersteel" at 66 or 67 HRC, it could be ground a little thinner, because strength is directly related to hardness. It is stronger. I'm not saying that you can't snap it or break it, but the edge can be run thinner because is it stronger than the same steel at 57 HRC. This gives you 2 advantages:
1. You don't have to use as much pressure to make the cut, so the edge lasts longer.
2. Being stronger, the edge resists deformation much better, and the edge lasts longer. Obviously, this will depend upon what you are cutting, but things like wood, plastic ties, etc., aren't that abrasive, so they will try to deform the edge more than wearing it away. The stronger steel supports the edge more, and will stay sharp longer.
Notice I'm not saying anything about carbides or abrasive materials. For your "supersteel", if you could get 2 identical knives in 1095, one at 55 to 57 (very typical), and one at 65, you'd be shocked at the difference. IMO, 1095 at 65 is a supersteel. So is M2 HSS at 66. Neither one is exotic, but they really work.
And contrary to popular opinion, these super steels are EASIER to sharpen. When they are run hard, they don't burr like the softer steels, and give you nice crisp edges.
1095 at 65 would be a super steel compared to 1095 at 58 in every way possible, but even at 65 it's still 1095 so it won't compare to the high alloy steels that can be run at the higher hardness ranges.
Yes it would be better, a lot better when compared to 1095 at 58, but with very little carbide content steels like 1095 depend on hardness completely for wear resistance so 1095 at 65 would be noticeably different than at 58.
Just posting this before some tried to say something stupid like 1095 at 65 HRC would beat (enter super steel here) because it just won't due to the low alloy content.
Or someone will post that 1095 with good HT will beat any supersteel with bad HT. Hehehehe, like it's easy to find bad HT from good manufacturers these days...
Correct. I see a lot of posts lately that "good old" 1095 at 55, 57, or whatever "just plain works", or words to that effect. 1095 at 65 just plain ROCKS, it makes the 57 HRC steel look like sharpened sheet metal, and if it's used for cutting (not chopping or prying), then it REALLY shines.1095 at 65 would be a super steel compared to 1095 at 58 in every way possible, but even at 65 it's still 1095 so it won't compare to the high alloy steels that can be run at the higher hardness ranges.
You're right, if a "super steel" with more carbides and hardness enters the picture, then it will be even better. That's why I was trying to focus on deformation rather than abrasion.
So my point is: for all you that like to use a knife for cutting and not anything else (which is almost a mantra in the traditional forum), try 1095 at 65. It's better than at 57 IN EVERY WAY. It even sharpens easier, and you'll get at least 5 times (or more) the performance. There is no downside, assuming you're not trying to open paint cans, etc. Once you get used to that performance, you'll want to try something even better...![]()
I wish I still had one of my old S30V knives from years ago, I'd send it to you. It might compare favorably to pot metal, but it would be close...Yeah that won't happen either, even S30V at 55 HRC isn't THAT bad assuming they didn't blow out the grain.
A race to the bottom, for sure!Oh I had one at 55 HRC, that's why I mentioned it.![]()
Why buy a super steel when you don't need it?
I can almost always identify the steel by taste.
If you take Spyderco Mules and hold them by the same hole in the bare handle and thunk them, they all have interesting tones. If you're not hearing it, try a different hole.![]()
Yeah, I admit I would like to have some of my knives in super steel. Have the edge last a lot longer, sure it would be great. The thing is, all that I'd wind up doing with it is opening my mail, food packages, cut the odd thread off stuff. You know my general EDC chores. Doesn't really seem worth the extra price.
On the other hand, if I was going to buy a dedicated skinning knife, or a knife for basically any task that was going to require cutting a lot of a specific material, then I might want to invest in a better steel so I don't spend more time sharpening than cutting. The thing is, I have my doubts most people that possess these knives with super steel actually benefit from them. They just buy them to have the latest and greatest, when all they're doing is opening mail, packages, the same type of EDC stuff that 90% of users actually use a knife for.
That's the only thing I don't get about them. Why buy a super steel when you don't need it? I understand the attractiveness of having "more than you need", having top quality available, etc. However the price disparity between some of these steels is just enormous, that I don't really find it worth it myself. To each his own I guess.
