Do you want to compete in Bladesport or do you want to win?
Many of the top competitors use M4. The winner uses others steels (Vanadis 4 Extra & PD-1). Maybe Dan uses the other steels as a handicap to give his competition a better chance of winning? Or maybe he uses other alloys to gain an advantage over his competition? What does common sense tell you?
Chuck
What? I'm just trying to figure out if M4 cuts straws better than L6.
Do blades of 52100, 5160, L6, or O1 fail to make the fine cuts in the pool noodles, straws, paper towel tubes, or rope? Are the cuts made by CPM M4 superior?
I am willing to bet that if someone, somehow, swapped out his Vanadius blade for an exact duplicate in 1084, he would still do as well in that particular course and many would praise Vanadius 4E. I'm sure edge retention issues would rear their head, eventually... I'm not denying the performance potential of modern alloyed steel. I realize that I am making certain assertions here... it is just my personal opinion.
So that blade has about a 4 degree per side primary flat grind, with just a little flat near the spine? A full flat grind on a 1/4" x 2" blade gives a 3.6 degree per side primary angle, or ~ 4 degrees. This is before any curvature or other blade profiles are taken into account.
I think that Dan, like so many of us, uses what he feels is the appropriate steel... based largely on research done by others. Which works. I am not trying to downplay a knifemaker's ability to test their own knives but that steel exists because industry developed it. I met Dan at Blade Show this year and he is the nicest guy, intelligent and funny. He is also a substantial brute of a man... I can see why he uses a Silverback image for his business. I am willing to bet that if someone, somehow, swapped out his Vanadius blade for an exact duplicate in 1084, he would still do as well in that particular course and many would praise Vanadius 4E. I'm sure edge retention issues would rear their head, eventually... I'm not denying the performance potential of modern alloyed steel. I realize that I am making certain assertions here... it is just my personal opinion.
I would take the bet.I am willing to bet that if someone, somehow, swapped out his Vanadius blade for an exact duplicate in 1084, he would still do as well in that particular course and many would praise Vanadius 4E.
Now like mentioned it has more to do with geometry and technique than the steel itself.... But "better" steels can be ran thinner and harder... Meaning better geometry with less risk of a failure, like rolling or chipping.
Greater edge stability at thinner cross sections will surely trump in a cutting competition... I'm probably just overthinking this whole thing... stuck in the house on a rainy day.
