- Dec 27, 2010
Thanks everyone!
Thank heavens he returned a couple of months ago, so hopefully sand won't be that much of an issue anymore. How much bigger are the 300 and 550 compared to the 350?
PS - the 550 is just such a gorgeous knife...
Copying from a reliable retailer:
Zero Tolerance Model 0300ST Combo Blade, Black G-10 and Titanium Handles
Specifications:
Blade Material: S30V stainless-steel with Tungsten DLC coating
Blade Length: 3-3/4 inches (9.5 cm), partially serrated
Blade Thickness: 0.156 inches
Handle Material: 3-D machined, G-10 and Titanium back
Handle Length: 5-1/4 inches (13.3 cm)
Lock: Titanium frame lock
Weight: 8.0 oz.
Includes SpeedSafe® Ambidextrous Opening System (available in manual also)
Includes a quad mounting system for tip-up, tip-down, left or right handed clip carry
Made in USA
Zero Tolerance Model 0550 Folding Knife Black Plain Blade G-10 Handle
The ZT0550 features a bullet-tough blade of S35VN stainless steel. This ultra high-performance steel is a third-generation powdered steel. So it’s incredibly clean with virtually no inclusions and has an exceptionally uniform distribution of carbides. In other words, it can take whatever you can dish out. Designed by Rick Hinderer.
Specifications
Blade: S35VN blade black finish; 3.5 in. (8.8 cm), 0.156 in. thick
Scales: Textured G-10 in matte black; 4.5 in. (11.4 cm)
Overall: 8.125 in. (20.6 cm)
Lock: 6AL4V Titanium frame lock
Weight 5.8 oz.
Made in USA
ZT O350
The Model 0350 Zero Tolerance is Slightly smaller and lighter, but just as Aggressive. The new 0350 is 10% smaller the the 0300, but packs a lot of features into a size that some users prefer. Like its larger counterpart, the 0350 features the patented speed safe assisted opening system. Deploy the blade quickly and easily using the ambidextrous thumb stud or index finger protrusion. The ZT0350 features a S30V stainless-steel blade. S30V steel is extremely durable, Corrosion resistant and wear resistant. The high performance S30V blade is Paired with black G-10 scales for a secure grip and excellent mechanical strength even under the roughest conditions. A locking liner secures the blade. The 0350 also includes ZT-s quad mounting system for complete versatility. Mount the user clip in any of four ways: tip-up, tip-down on the left side or the right.Includes Speed Safe ambidextrous Opening System and a quad mounting system.
Specifications:
Blade: S30V Stainless Steel
Blade Length: 3 1/4 inches, .121 inches thick
Scales: G-10 Matte Black, Textured, 4 5/8 inches
Lock: Liner Lock
Weight: 5.8oz.
Made in USA
If he's not too worried about sand, I'll throw a couple more in the mix:
Doug Ritter RSK-1 Griptilian (or mini-Griptilian). This is my favorite EDC knife, hands down.
"Not everyone can afford $200 or more for a top quality folding knife. Even $150 is pushing it for many. However, everyone deserves a knife they can trust their life to in extreme conditions, a knife you can bet your life on™. The Doug Ritter RSK® Mk1 meets that goal at an affordable price. This is a collaborative evolution of Benchmade's Griptilian™ folder produced exclusively to Doug's specifications. "RSK®" stands for Ritter Survival Knife, an indication of its strength and reliability, but it's really a perfectly practical everyday carry knife. Thousands have been sold and are in daily use throughout the world, from urban city to Alaskan wilderness to Middle-Eastern war zones.
The sturdy black ergonomic glass-filled Noryl GTX handles, stainless inset liners and patented super strong ambidextrous AXIS™ Lock are pure Griptilian™. This is a handle that just plain works with a secure non-slip grip and a pronounced finger guard for safety, as well as a full-size lanyard hole. The pocket clip is reversible.
What helps sets the RSK® Mk1 apart is Doug's wide-chord and robust drop point blade design. This is a traditional blade style, very strong all the way to the point and very versatile, if not particularly "sexy" or "tactical." In today's politically correct world, that may not be such a bad thing for an everyday carry blade.
The blade's spine incorporates a prominent ramped thumb rest for enhanced control and security. This thumb rest portion of the spine also does an excellent job creating sparks using an artificial flint and can be used with the knife closed for added safety.
The 3.44 in. (8.74 cm) blade has a high, flat grind for cutting ease and strength. This grind makes for excellent slicing geometry; field reports confirm that it is an extraordinarily efficient slicer.
Dual thumb lugs provide ambidextrous opening, easy even with gloves on, completing the fully ambidextrous nature of the RSK® Mk1.
Topping this all off, the 0.115-inch (2.92 mm) thick blade is made of Crucible's superb, premium performance CPM S30V high-carbon stainless steel. It's proven tough and holds an edge.
The blade finish is a strikingly beautiful, but very practical "stone washed" tumbled finish that also serves to seal the metal's pores for added protection and strength. The result is a subdued finish, but one that is smooth and just barely lustrous. The finishing media and process was designed expressly for this knife to get the exclusive finish quality Doug desired."
Blade Material CPM S30V hardened to 58-60 HRC
Blade Length 3.44 in. (8.74 cm)
Blade Thickness 0.115 in. (2.92 mm)
Blade Shape Wide-Chord Drop Point
Blade Grind High Flat grind
Blade Finish Stonewashed
Closed Length 4.62 in. (11.73 cm)
Open Length 8.06 in. (20.47 cm)
Weight 3.82 oz. (108.29 g)
Handle Material Glass-filled Noryl GTX
Liners 410 Stainless Steel
Pivot Washers Phosphor Bronze
Pocket Clip Ambidextrous Reversible, Removeable, Parkerized Stainless Steel
Lock Mechanism Ambidextrous AXIS Lock
Opener Ambidextrous Dual Thumb Studs
Spyderco's Manix 2 Black G-10 Handles, 154CM blade with satin finish:
Dimensions:
Overall: 8 in. 203mm
Closed: 4 5/8 in. 117mm
Blade: 3 3/8 in. 86mm
Edge: 2 7/8 in. 73mm
Weight 5 3/8 oz 150 grams
Locking Mechanism: Ball Bearing Lock
Tip-up, Reversible Pocket Clip
Made in Golden, Colorado, USA
I think most of Spyderco's other offerings he'll find too big in the handle department (I know I do), but the Manix 2 is a heck of a nice knife. I own 1, with the second arriving in the mail today.
