if you focus on edge retention and corrosion resistance: you may consider S125V or S90V .... corrosion resistance 7.5 should be still good -
what style? folder? ...fix blade? ...blade size?Do you know any US makers pushing those steels to 62+? All I see is Magnacut.
Eta: something like this: https://www.knifecenter.com/item/BM...range-g10-handles-orangeblack-boltaron-sheath ? ....Note that every steel has his "healthy" hardness range, if you exceed this the steel becomes so bridle that you have to be careful not to drop it as it would just break from the drop.
...it still has a significant better edge retention than MagnaCut - edge retention is a combination of hardness, carbide volumes and carbide hardness and not just hardness. The particular combination is specific for every type of steel; MagnaCut requires a higher hardness to achieve its specific edge retention ... see https://knifesteelnerds.com/2021/10...ness-edge-retention-and-corrosion-resistance/Fixed EDC size 3 to 5" flat grind
I saw that Benchmade, CPM-S90V but only 59 HRC: https://www.benchmade.com/products/15002-1-saddle-mountain-skinner
I know man. Sadly my comment about BR grind lines being wonky is too true to be a jokewas a joke, not serious....
My advice is - go with Reiff in CPM-3V steel.
3V is personally my favorite steel.
you hijacked my threadedge retention 4.5 corrosion resistance 5.5
S100v and S125v aren't anywhere, so S90v looks like the winner, which means Benchmade or...another Benchmade.
you hijacked my thread...(it's o.k.) ...EatingSarma's post may refer to my question (Bravo 1.25 or Reiff F5) that started this thread (?... not sure about this so....)
Yep. I answered to you.you hijacked my thread...(it's o.k.) ...EatingSarma's post may refer to my question (Bravo 1.25 or Reiff F5) that started this thread (?... not sure about this so....)
wrt Benchmark: that design of the tang is a bummer - they picked the right steel that won't dull so easily for the job, and then they spent labour and money on the tang to make something that was - as a standard design - perfect for the job into something really bad....ouch ....Lol, you're right. And I'm back to square one anyway because the only s90v available is perfectly designed for trapping blood and fat inside the handle.
Back to your thread topic, here's two suggestions for you since you like 3V:
Bark River Cub 3V
and the CRK BFK 3V 62HRC, actually going on sale today
I take #2,#3 and #4 .... can pay in eggs ....From left to right:
1. McNees Ridge Runner in CPM 3V
2. Reiff F5 in CPM 3V
3. Carothers BFK in Delta 3V
4. Bark River Bravo 1.25 in CPM 3V
5. L.T. Wright Genesis in A2
6. Rokka Korpisoturi in 80CrV2 Carbon Steel
www.bladeforums.com
