Bravo 1.25 or Reiff F5?
update:
wrt sheath for the Bravo: it is actually not so bad, and despite the information from a YouTube channel I saw, it is actually not so tight as it looks like. Due to the design / style it comes totally flat out of the box, but it actually breaks in pretty fast. For the width of the Bravo blade, it is a little bit too wide, hence the Bravo wiggles a little bit in it. However, it actually fits the Reiff F5 with the little bit wider blade like a glove 😀.
wrt Bravo 1.25 LT vs F5:
- if you are younger and want to impress the chicks: Bravo wins, but you may choose a fancier handle, maybe with a liner and some fancier colours instead of old fashion classic black micarta 😃.
- as a hunting knife or for meat processing: I give the Bravo the edge here as it is lighter (204 g vs 284 g) and nimbler... I assume the same is valid for food processing (still have to test this so).
- feather sticking: no clear winner - more testing required. That is a little bit a surprise, I thought the Bravo would be better here, but - due to the F5 "custom" handle? - the F5 is surprisingly good. Interesting: the v-edge of the F5 seems to facilitate extreme tight curls, while the convex of the Bravo seems to give me more control wrt to producing finer or rougher feathers; I never noticed this (difference between v-edge vs. convex) before.
- carving / typical bushcrafting: I give this to the Bravo - everything I can do with the Bravo I can do also with the F5, but the F5 is just heavier, and the same work seems to be a tad (only a tad) easier with the Bravo.
- batoning: the Bravo is not bad, but the F5 is / seems to be just more robust. I picked - by accident - a pretty dried out piece of hardwood which proved to be pretty challenging. With the Bravo I might have given up as I didn't want to risk any edge rolling, but the F5 (thicker spine, "heavier / more steel", robust v-edge vs very acute convex) seems to be just more suitable for this kind of tasks (disclaimer: this is not scientific evidence - it is just based on the 'feeling" I had when doing those testing).
- chopping: F5 is the clear winner here due to the weight advantage, the overall handle geometry and this little bit real estate more of the handle that allows a more secure grip towards the end of the tang.
- buying experience: for both knifes a 10 out of 10 - I bought the Bravo 1.25 LT (first and only BR knife so far) via DLT Trading, the F5 from Reiff's website; I had some email traffic with both companies, and both companies made a real effort to answer my questions in a timely manner. I'm aware that some BR customers had disappointing experiences, however - note that my comments here are just anecdotal - I really can't complain.
in a nutshell: both are fantastic knifes, both knifes tick all the main boxes (3V steel, 5" blade, kind of allrounder / good compromise between bushcraft and field knife). The handle of the F5 is like custom made for me, the fit is really remarkable. Every task I can do with the Bravo I can do with the F5 too, also for some tasks (bushcraft, meat processing) the Bravo seems to be slightly more suitable. However, for tasks that require extreme toughness I trust the F5 a little bit more - it is possible that the normal version of the Bravo 1.25 with the much thicker spine could match the F5 for these tasks, but I leave this to others to find out.
Thanks for all the comments here that helped me with the decision making - very appreciated. I ended up with not 1, but 2 quality knifes, both excellent suited for the intended use. The only problem I left with now is, that every time I go on a 3-day hike with minimal gear I have to decide, which one of these 2 beauties I will pick for the particular trip.... could be worse 😀.
Eta: I will add some pictures of these 2 beauties once I find the time to figure out how to do this....
it is a little bit misleading just to compare the overall length and the blade length of the knives: while the blade length is the same, and the handle of the F5 is just a tad longer, the F5 is just the much "bigger" knife: approx. 30% heavier, thicker spine, wider blade, thicker handle. The taco style custom sheath (from a smaller knife) fits the Bravo nicely but doesn't fit the F5. The original BR sheath for the Bravo fits the F5 much better than the Bravo - it is o.k. for the Bravo, but there is a lot of space, and you can wiggle the Bravo forth and back.... I wet-formed the Reiff sheath (very easy to do), now it needs some weatherproofing with sno seal.
update wrt feather sticking: did more testing with different wood, and yes, the Bravo - as expected from a blade with a more acute edge - performs overall better than the F5 with the 20 deg edge.
Eta: added content from other post (took me some time to find the correct photo link).
Eta: added content to previous post (after figuring out how IMGUR works).
final thoughts: both knifes will serve me well. Most of the time the Bravo will be enough (the approx. 150 g weight saving equals 150 ml water that I can add to my pack limit, e.g. for a 3-day hike in areas with water shortages). For longer hikes, and for hikes where I don't have to count each drop of water, the F5 will cover those unexpected Armageddon scenarios too (I can likely cut a whole tree with this beast and carve a canoe out of it if I have to 😃 ).
yeah, that's the times we live in .... as you may have recognized from my other comments here, I take complaints about manufactures with a pinch of salt and try to figure out which of the complaints are valid and which not.
I’d be happy to share my experience. Though I’ll have to see how much I have saved as the weak cuck blocked me after confronting him about his dodgy magnacut knives on bark river fb page. Simply asked why he’s the only one claiming it’s not stainless, when spyderco definitively made it so and I also got a north arm mallard that responds very differently to corrosive substances. He sells them knowing people expect very stainless knives, only to find out they’ve been duped because a ‘master’ is dodgy as fuck
edge retention 4.5 corrosion resistance 5.5
S100v and S125v aren't anywhere, so S90v looks like the winner, which means Benchmade or...another Benchmade.
I’d genuinely look into custom makers. I’ve recently bought 3. Jc bladeworks and db knives (Aussie makers) I didn’t get ‘super’ steels as these were baby steps into the custom world and the heat treat is insane compared to almost all production.
I sent an email to Reiff to the email address mentioned under "Contact" on their website - still waiting for a response. Does someone know whether this email address is still valid and how long it usually takes till they respond?
I get responses with in 48hrs and some times same day.
Lol, you're right. And I'm back to square one anyway because the only s90v available is perfectly designed for trapping blood and fat inside the handle.
benchmade-15002-1-saddle-mountain-skinner-fixed-blade-knife-15002-1__67075.1601496174.jpg
Back to your thread topic, here's two suggestions for you since you like 3V:
Bark River Cub 3V
and the CRK BFK 3V 62HRC, actually going on sale today
img_7680-jpeg.2762047
If you’re looking for a good hunting knife around 4” look at TRC polheim in magnacut they run there magnacut between 62-63 HRC. Keeps an edge long and has a nice belly for Bambi season.
Micarta has - IMO - more character, it's more like timber. However, for this knife and the intended use I actually would prefer G10. Reason is that G10 is tougher than Mircarta, stains less thus it is more hygienic and easier to keep clean.
E.g. this new knife will very likely see - amongst other challenges - also some roadkill: the wallabies - that are the smaller kangaroos here down under - are, like their monstrous bigger cousins, sometimes very suicidal and jump head forward into cars. If such roadkill is fresh and not smashed, it makes actually an excellent dog food. (As a native animal hunting them is not allowed! .... sometimes kangaroos are culled if the numbers are too high, but there is a lot of paperwork involved.)
Kydex and G10 scales will make it much easier to facilitate some hygienic standards.
Eta: ....I might have to use it sometimes also to defend myself against dropbears (one of Australia's unknown dark secrets ....)
My cousin got eaten by a dropbear. All we found were his feet.
