- Aug 5, 2005
pjsjr said:...Do you think that a 560 could be converted to a takedown verison?
I haven't seen one yet, so I'm not sure...I have looked at that 186 pic from eBay, showing the 186 stripped down...The 186 has a tapped liner/scale on one side...
But the 560 is riveted...so if you wanted to use a screw the same size as the rivet (I'm guessing 5-40), you'd have to plug the rivet holes on the back side of the 560 and then tap the plugs...or you could use a smaller size [2-56] and run a screw from both sides into a long 1/8" OD tapped stud...
And the 186 uses a special bushed rockerbar...not a standard 110 part...so if the 560 uses a 110 rockerbar, you'd have to build the metal up where the hole is to take a bushing...or just leave the screw loose...
I don't have the tooling precise enough to make 1/8" OD studs with 2-56 internal threads...and neither Jantz or Texas Knife have 1/8" OD studs long enough...
But I probably could press in a plug...and tap it 5-40...
So far, that's my thinking...
I can probably make a Titanium scale, though...Here's my thought on that: Strip a 110, mill the bolsters flat, make a Titanium full-length scale w/560 profile & 5 holes drilled through, assemble so that the brass liner is visible through the Titanium bolster...use 110 blade/rockerbar/spacer/spring for simplicity...tap one scale for 5-40, relieve the other scale for the head...deal with the blade & rockerbar pivots with some sort of bushing (still looking into that)...
Actually, I'm going ahead with this idea...if the Titanium proves too tough, I'll use 304 SS instead... :thumbup:
Finding the time is the big obstacle...
