Buck switched from 440 because they wanted to fine blank their blades and could not do it with 440, that is why they made the first switch to 425 about 1982 (440 did not like to be cookie cut). Followed by the 425 to 420 about 1992 for cost savings that David mentioned. Note: FYI the steel change data and dates can be found in the Blades Guide.
JB
This guy is tripping me out. We are a family of Buck entnusiasts.
Welcome to the family.
What you're experiencing is called Brand Attachment. It's a pretty severe level of advertising manipulation and is completely illusory. The stuff you buy is not an extension of yourself and neither are you party of any "family" because you bought their stuff.
Speaking of blade steel and Buck Knives - just got this one in the mail Saturday, a new 2014 built Buck 118 made of D-2 steel (thanks to David Martin for being my steel research resource on this one). Going hunting tomorrow, might just get to try it out. It came ready to skin and butcher a deer two - no touch up needed. OH
Marfan can you give an example of what you call dull? Will it still cut topping paper, notebook paper, newspaper shave your arm? I'm very curious about your experience and would like to do some comparative testing with a "donated" Buck I have. Also, how do you sharpen your knives? This can have a large influence on edge retention and you may do it completely differently from me. Edge angle, grit, burr, alternating passes, etc.
LOL! So you're ok and we're all brainwashed?
Also, there are more forms of advertising than your realize.
I measure dull as in how hard I have to push and if the blade cuts or tears through the material. If you're talking about whittling you can feel when the blade stops cutting and starts mashing/bullying through the material. Also, I look for plastic deformation along the apex by trying to reflect or "catch" light off it.
As for how I sharpen, I'm very proficient with bench stones. I also use a turnbox and that lansky clamping jig system. Occasionally I'll sharpen on the underside of a coffee mug if that's all that is available.
Edge angle: on these Bucks I use about 22-25 degree.
Grit: I usually finish at 600 or 1000
I use the burr method on bench stones, but not the gizmo systems. If I'm using a turnbox I'll microbevel typically.
I consider myself a proficient sharpener.
If my criticism of Buck elicits an emotional response, then yes, you are suffering under the illusion of brand attachment.
So when you typically resharpen, would the blade still slice typing paper before resharpening? How sharp are the knives after you've resharpened them? Will they shave hair off your arm? Can you fillet print/letters of a page of news paper?
