David,
Sorry, but seriously? You think this is a valid test to be able to make the claim that a coarse edge will satisfy 99% of sharpening needs, based on you sharpening one type of knife and slicing thru some rope? What if you added a serrated blade to the testing. Tried a different type of knife. Different steel. Different edge geometry. What would your conclusion be then?
I don't know about the others you mentioned, but you need to reread Juranitch's book. Better yet, get one of his fine hones he uses to finish a blade. He doesn't support this at all. In fact, here's a few quotes from his book (p.19):
"We have to confess when we were just getting started we thought the same thing" (You're supposed to have "teeth" on your edge). "As we got into our research though, the idea of teeth turned into nonsense." "If the edge was really sharp, we could see no teeth whatsoever."
"The fine hone is just the opposite" (of a coarse hone). "You want it as hard as possible, and the grit as fine as possible."
And from p.55. "Once that is accomplished,..." (setting the edge) "...you have to go to the other end of the rope to finish the edge. And how fine do you go? Just as fine as you can.
It's not possible to go too fine." (Emphasis added by me.)
I also went and read Talmadge's sticky post. The only thing I could find related was this...
"Edge toothiness: Some steels seem to cut aggressively even when razor
polished. For these steels, even when they're polished for
push-cutting, their carbides form a kind of "micro serrations" and
slice aggressively."
I'd hardly call that a supporting claim. If anything, it shows why your testing is invalid. You don't even account for the steel.
All I can say is Wow.
This is not a good test. All it is a test designed to support a conclusion you already had, if that. You could easily conclude that the edge wasn't properly refined, which, BTW is supported by the polished edge showing burring after 3 cuts. It would be easier to conclude it was improperly sharpened, explaining why it performed so poorly.
Good god, I actually tried to walk away from this, but I can't get it out of my head. What an awful test. The ONLY thing you can even remotely conclude is that: "David Martin gets the best performance on a V52 Selector blade sharpened on a Norton stone cutting 1/4" sisal rope, by leaving a very coarse edge on the blade." The fact that you didn't even attempt to eliminate any other factors means you really can't say anything else.
Don't take this personal 'cause it's not. It's just really really bad science. If you hadn't tried to generalize this to 99% of the rest of the world it wouldn't be a big deal. But the fact that you did, makes it really really wrong. Sure, it's one piece of the sharpening puzzle, and good info to have in that respect, but it's a very very small piece. Trying to add support from more knowlegeable sharpeners, Talmadge and Juranitch, (which turns out to not be very supportive), is a bit disingenuous.
cbw
