David Martin
Moderator
- Apr 7, 2008
cb, Glad you took the time to conduct this test we may both learn something . What steel does your knife hold ? DM
I've worked on a few ideas of why fine edges 'fail' (discussed below), but hadn't tested them in this manner.
I think alot of times, people that find a coarse edge better, or that a fine edge fails or doesn't cut at all, is because it was improperly sharpened. For me, one of the biggest points is that a fine edge doesn't equal a smooth or rounded edge. It will still have "bite" and will penetrate to cut. But it's at a very refined level. You also have to insure that you don't leave a burr or w
wire edge... which is easier to do at this level.
Ultimately I know that it's your knife... sharpen and use it how you see fit.
cbw
Yes, its obvious you've not done any test like this because if you had you would have stated several items in the parameters up front . Instead you went on for paragraphs not telling what I did ? Now, if you really want to make a point that compares with my findings you'd take that same knife and sharpen it using a coarse grit of 280 then start cutting more sisal rope . For an accurate comparison !! DM
Out of interest, to what variables would you attribute the discrepancy between cbw's results of 400 cuts with no demonstrable deformation, and your results of 4 cuts with obvious burrs?
Any Cal, I'll answer your question, just to reiterate my point. From this testing, you can't attribute the discrepancy to anything, becasue it could be anything or a combination of things.
cbw
Yes thats a big variance and I'll look into that but that was not what the test was about . In the mean time unless someone sharpens that knife steel at a coarse level and conducts the same test cb's results are at best lacking/incomplete . Different steels are capable of holding a finer/polished edge better than others but thats not getting at this point . Perhaps yours . What I sharpened on was what a normal household may have available to sharpen knives on . Taking it to that high a polished level most households won't have anything near that available . DM
It doesn't matter if published materials support his results. That doesn't amount to a hill of beans! What if you were to state that Dave's results do not support Juranitch's position?
Only knowledge can be gained via reading, NOT experience. A very knowledgeable person with little to no experience can merely say, and not do.
