- Jun 9, 2011
I have had a jolt close a knife in my hand in use. Cutting hoses in very tight space. On a cubic hydraulic press. Push cutting and sawing a hose at an awkward angle and the knife spine contacted the steel side of fhe press. Cut my fingers. Not badly.
Different liner lock I was topping boxes at a job. Poked the knife into cardboard, and it closed on my thumb. Slight download pressure on the spine caused the liner lock to disengage.
Spine walk tests cause many style knives to close.
It is damaging to liner locks and frame locks.
I do check my liner locks and frame locks and back locks to check that the lockup is tight.
I have Triad locks that won't fail a spine walk test....but I don't need to bang my edge on anything to double check that.
So I've been cut when a liner lock failed with light negative pressurez and also a separate liner lock with a slight jolt to the spine.
My older brother was cutting thick sidewall rubber ( trying to pierce to initiate the cut).. he had to have surgery to reattach his tendon.
I've seen more than a few other cuts from liner locks and frame locks.
I have retired liner locks for the locks repeatedly disengaging with light spine pressure.
on liner and frame locks. if the geometry is incorrect you don't have to spine whack to test it. a simple keep fingers out of the way and press on the spine and watch how the liner or frame lock moves. proper geometry will stay still and move towards more lock up. improper will move towards unlock. doesn't require a lot of force to see and won't harm the locks either. I test all mine before carrying them.
