unwisefool
- Jan 22, 2007
My previous post was in response to MT_POKT.
if the screws on the strap were tight then the whole lock assembly and or the back spacer had to have moved backward? Something must have been loose for that to happen no? Did it have a very hard landing (dropped a long way?)? I am surprised to hear this account of yours so thanks for posting. Have you since been able to set the knife back up to function properly?
Ah ok, I was confused who you were replying to.
Nothing was loose, the part of the backspacer that the strap is attached to forcibly moved backwards alomg the adjustmemt screw enough that there was not enough clearance for the blade to engage the strap. It was a fall from a little less than counter height.
When I originally posted it people on the buck forum attacked me for somehow causing the issue, comparing it to me running a car into a tree or some such nonsense. But if I drop a framelock, it still works. I know shortly after I posted the same thing happened to another member as well.
I was able to fix it but I don't trust it anymore, I like to know that my knife will work all the time. Yes, it's a strong lock, as long as there is no force against the front of the strap.
The flaw is that there are too many moving parts, if the backspacer was one piece instead of two adjustable sections, it most likely would have still worked. So that's why I just use it for gardening around my cabin now.
