David Martin
Moderator
- Apr 7, 2008
Those knives are very much like the Vanguard 192, the 103 and Josh's new skinner which I forget the model #. I see no real advantage here in shape.DM
In an earlier post you put your steel at 2 microns= .oooo4" . So, which is it?The whole point of making powder steels which is very expensive is to decrease carbide size so yes, you are right. But they still are large in our world.
Maximum carbide size diameter for:
1. Coarse grades like D2, 440C, ATS34 etc = 40-50 microns (0.0018")
2. High alloy PM steels like CPM 154 CM = 7-10 microns (0.00032")
3. Fine carbide steels like 13C26 and 12C27M = 2 microns (0.00008")
We define a sharp edge as haveing a radius of maximum 1 micron. So that is where our requirement comes from. Any carbide larger than 2 microns in diameter will make the steel more difficult sharpen to a high sharpness level.
Regards
//Jerker
Does S30v with 4% Vanadium have better edge retention than ZDP189 which is a pure Carbon-Chrome steel? I believe carbide density is more important than carbide composition, but i'm not sure. Vanadium carbides are harder than chromium carbides but I believe that the carbides mainly tears out, not wears down. Not sure though.
Regards
//Jerker
Does'nt matter, its still small.DM
Sir,I must comment on this one as it is a major junction which you brought us to stand.You may have some legitmacy in the carbide density thinking vs carbide composition as I seen this w/ the CPM steel performance.S30V and S60V I noticed it will cut only about 1/3 of its ability really sharp and 2/3's sluggish.Say S30V is capable of cutting up 1500lbs. of meat. Only 500-550lbs. will it cut up w/ a really sharp edge the rest it will cut up but w/ a not sharp edge, more sluggish.I know this is the vandinum taking over which are harder carbides to hold that edge longer. But I don't care for the "slow" edge.Does S30v with 4% Vanadium have better edge retention than ZDP189 which is a pure Carbon-Chrome steel? I believe carbide density is more important than carbide composition, but i'm not sure. Vanadium carbides are harder than chromium carbides but I believe that the carbides mainly tears out, not wears down. Not sure though.
Regards
//Jerker
I had rather have a edge which cut like lighting all the way until its dull and you know its time to sharpen it than something cutting which your uncertain if its time to sharpen or not. Say, like 440C @60-61 will cut up 1000-1100lbs.all w/ a lighting edge and when it begans to cut sluggish you know its time to sharpen.Well, you just cut twice the amount as S30V with a real sharp edge before requiring sharpening.To me thats an advantage!
This field testing would substantiate your thinking that carbide density has a more positive effect on edge retention than carbide composition.Hence, what you surmise is we actually don't need vandium nor alot of other elements in a knife steel to attain great cut ability or good edge retention. DM
Jerker, A steel attaining 2micron edge is needed for shaving whiskers and can be of benefit in cutting procedures especially where fine cuts are required.But for merely lopping off a hind leg such as in field dressing a large mammal. Some may notice those benefits but what Americans notice is rust, how long it cuts and ease of sharpening.DM
