- Jul 30, 2006
I have a number of both Case and Buck, and each have strong points and weak points in comparison to one another. For a pure work knife, I would likely go with Buck, from my experience.
One question on the Buck 301:
I've noticed on the more recent models, the tip and part of the edge of the spey blade looks exposed when in the closed position. Does this cause any problems for the pocket material, or when reaching for it in a pocket? I'm considering buying either another 303 or a 301. I don't think the new 303's spey blades are exposed as much as the 301's, but I'm not sure.
Jim
The 303 spey is much less exposed.
I've never caught anything in the 301 spey blade. Not a thread. Not a finger. It looks as if it were a problem, but functionally it is not.
Is this is a common occurrence with the tip being exposed? Is there a reason why Buck hasn't done anything to fix it or maybe Buck doesn't see it as a problem and just part of the knife. This no longer has me wanting this knife but now heading in the GEC direction for a stockman. I already have an Old Timer that I'm happy with but looking to add another stockman.
Some years ago on the Buck Forum, I had a conversation with CJ himself about this. I pointed out that the issue is caused by the orientation of the covers, not the orientation of the blades per se. It's due to the serpentine shape of the frame. In order to fix it, they would have to swap the blades end for end. CJ even talked to his engineers about it. But they reached the same conclusion that I had. To change it, they would have to completely re-tool. VERY expensive. They cannot address it economically until the current tooling wears out and they have to re-tool anyways. Because it's a minor cosmetic issue, rather than something that causes functional problems, we all just go with it.
They should have left the blade configuration alone so the 301 wouldn't have this issue.
Read my comment above. It isn't the blade configuration.
I carried a Camillus made 303 for years. I've carried new model 303's and 301's for a few years now. I much prefer the new design to the old. It just works better.
