- Oct 17, 2007
Thanks! It makes perfect sense, now!
When you disassemble a finished knife, can you get the ball out, or is it being held in place?
I suppose if the hole were small, as you suggest, and you used a hydraulic jack as a press...
The detent balls are typically held in place using what is known as a "interference fit". In other words, the hole is ever so slightly smaller than the detent ball, so when it is "pressed" in, the liner material around the hole holds it in place. I've removed balls by punching them out form the back side of the hole, but you can generally only put a larger ball back in it's place, as the material is too stretched out by then to replace the same ball. I suppose you could peen the hole back tight again if you're careful, and THEN re-insert the ball, but I've not really had success with this; at least not when trying to position the ball at a specific height. YMMV.
Most makers just pop the ball in with a punch, as far as I know, though an arbor press can work as well. Typically, a bushing/spacer is used to set the exposed height of the ball, so that it can't be pressed in too far.
