When you sharpen two equal angles one side is reduced more changing the angle causing a burr to form on the side not contacting the abrasive. This happens because you are now cutting into the other bevel and if you keep going your knife will look like a chisel with a burr on the flat side. Cutting into a stone to dull the knife before sharpening only means that you now must grind the edge back to a point and if you grind one side slightly more than the other the burr will be back just like before. This is simple geometry, two angles meeting at the center line of the blade.
First, when you have put a blade through tough use the simple geometry question becomes complicated by the question of how deep into the steel have I weakened it? When I used my Spyderco Manix to take massive chunks out of a 1x3 piece of wood with hard chops and then tough prying to break off large pieces of wood how much steel behind the edge can that weaken? I don't know, but for whatever reason I have found I get less sharpening burrs when I cut into the stone prior to sharpening. Let's just agree to disagree on that.
It can be argued that sharpening to a burr is excess sharpening (my arguement), as you have already got the sides to meet and the sharpening is now causing a burr because you went too far. I would rather sharpen the slightest bit less than "perfect" and not have to remove the burr (if a knife is tree topping hair at DMT Fine I am getting pretty close to the limits of sharpness at that grit depending on steel) than have to start chasing the burr. As for Tom Krein's edges being so thin, I either own or have handled 10 Tom Krein regrinds and own 2 of his customs, some with edge thicknesses as low as .004"-.005" (got 3 of those around the house) and the thickest one has a .010" edge. Do these ultrathin edges help with pushcutting newspaper, I'm pretty sure they do. I just find it hard to comprehend that you refuse to believe anyone that doesn't follow your principles can get a good edge. There is life beyond one excellent piece of academic work.
Anyway, I guess I can go back and read Dr. Verhoeven's paper again. IIRC he was using much different sharpening systems and mediums than I do, and different angles than I do as well, but I should refrain from comment until I read it again because I don't remember all of the details of his shapening tools and techniques at this point. I don't recall an edge pro or many other excellent sharpening systems on the market being used in the paper, though, so it would be hard to call it the final word on sharpening unless he tried every system and technique on the market, though it is definately the most in depth scientific paper out there on sharpening that I have seen. The last time I read it I was a pretty novice sharpener, and since have used my own real world experience and tips and tricks from other sharpeners to help me refine my approach to sharpening. Anyway, I did remember learning a lot from Dr. Verhoeven like not using steels and that edge trailing strokes cause burring easier than edge leading strokes, which is why I even use edge leading strokes on my lapping film unless I have had too much coffee, in which case I strop. If you try edge leading strokes with a burred edge or unsteady hand you will rip right into that lapping film, especially the .05 micron stuff.
Let us just agree to disagree on this one, and I will read Verhoeven for the fourth time (it's been awhile). Just out of curiousity, what is your full sharpening routine? Do you always full bevel sharpen or do you use microbevels? Just curious as to how you get your edges, as they are definately impressive from the pics I have seen.
Mike
