Busse as a carry weapon?
Leviathan Arms
If you had to pick one Busse to carry as a weapon, which would you choose? And what sheath option? Pics of your knife and setup are a plus!
Knives are tools.
But, there are some nice small to medium Busse knives for you to choose from.
righ now i carry the rmd in a NOE randall pouch horizontal hande facing left and glock 19 in a raven concealment phantm holster on my right side. I wll also be getting the same type of sheath made for my ASH1 ad will carry it the same way. Iwill try to post pics when I can.
Sfno or tglb
Spec ops or semper paratus.
Nylon plus kydex is the way to go for a combat sheath.
Rat said it right. Knives are never primary weapons, but if you have to use a knife, then it depends on your situation. Also, what can you carry concealed legally will be a factor. So two scenarios here, first would be the reality knife scenario which is what you EDC daily on your body. At best on a daily basis, most people will carry a small fixed blade or folder. So with that in mind, any of the 3-4 inch bladed light weight knives will work. The lighter it is the faster it is.
Now, lets talk fantasy and no guns scenario with broke down world. I would want the longest, lightest knife I could take. Wakisashi, 1311, or anything in the 13" + blade length would be minimum with a thickness of no more than 3/16 because you need speed to win.
But if you are reduced to using your knife as a weapon, things have really gone to hell.
I do carry a firearm(legally) but I would like a knife in addition. Simply want the option.
Some good options guys. Thanks and keep em coming!
a meaner or leaner meaner in a kydex belt sheath canted forward about 45 degrees, mounted reverse grip on weak side. you grab handle and draw forward and up so that knife comes out of sheath edge away from you and in your fist like if you are going to strike, punch forward. That is how I carry a small fixed blade, when I carry one.
For a weapon? An AK or a Gladius sounds about right ;) For a do-it-all tool I'm pretty happy with my TGLB so far.
This is the identical set up a friend had in addition to his pistol
I don't have a small Busse, need to fix that eventually....I currently carry a HRLM to augment the XDm
Edit more info: mashed cat kydex, weak side vertical...occasionally SOB horizontal
