Busse ASH Transformation
k_estela
Co-Moderator, Wilderness and Survival Skills Forum
Moderator
Warning: The following photo pictorial and comments will offend you if you are a Busse safe queen collector or someone who doesn't believe in modding knives. For those of you who like knives with serious function and purpose driven design, read ahead!
A while back, I purchased a Busse Anniversary Steel Heart from a fellow forum member, Longbeachguy. The knife as is from the factory was 3/16" thick and had the magnum thick handle slabs on it. It was coated black and the edge left me wanting more. Call me a convex and scandi slut if you want but I need an edge that pops hair and is still strong enough for woods use.
That being said, the knife began its conversion. First and foremost, I wanted to remove the grooves on the handle slabs. I'm not partial to ridges or any points that might cause hot spots. Out came the sand paper and away they went.
Next, I brought the knife to a gunshop I work for from time to time for fun. I used their bead blasting tank and removed the black coating. I personally don't like it and enjoy the feel of bare steel to painted finishes. The coating came right off with ease. Thanks JoJos Gunworks!
Finally, I took Siguy (Simon) up on his offer to sharpen some blades for me. I stopped by his shop and he did a number on this blade. First he made the rounded factory spine 90 degrees on his belt grinder and made it throw sparks like crazy. Then, he convexed the edge and put an almost mirror finish on it with his belt grinder, scotchbrite wheel and homemade (controversial) cardboard polishing wheel.
The end result, a Busse that is a pure performer!
3/16" in my opinion is an optimal cutting thickness for big blades. Too thick, and the blade binds, too thin and there isn't enough heft. This is just right. The medium sized blade is now a great vehicle blade or one to throw in my pack when I know larger blade chores will be par for the course. All in all, I'm happy with the transformation thus far.
Now, the real test will be the Winter Survival Course I'm teaching this Sunday through next Friday. You guys will have to wait for pics to see how it performs in the field. Don't you hate it when I tease you like this?!
The transformation continues!
sounds like a great modd, siguy is great at what he does. did the coating hamper cutting abilty? now you just need some wood scales on there (if thats your thing)
And it continues some more!!!
attachment.php
Sweet :thumbup:
Hope its not too thin :eek:
In theory, the coating will make cutting ability a bit less. How much? Only a machine could probably gauge it for sure. I like the feel of the bare steel myself.
As for the edge, it was really thick to start off with and this thickness is still substantial and should be fine. The problem with thick edges is once the initial sharpness wears out, the edge becomes thicker with each sharpening. You need to remove more stock to thin it out and make it cut efficiently again.
That looks great. I really like the ASH but the large choil keeps me from buying. I look forward to a full review from a non-biased reviewer.
that came out great... i like it much better..:thumbup: i bet it's sharp... i have handled some cool modded Busse's...
WOW! Great job... I am a bit of a mod freak myself, and have felt that many Busse blades can be improved (in my opinion) with a convex edge and stripping the coat. I also have smoothed the handles on a couple and have found that it works well.
I think you will enjoy the knife much more with it's modifications. INFI steel is great stuff. Let us know how it performs... my guess is that you won't be disappointed.
I have found that the coating on Busse knives greatly increases the drag when cutting through wood and certain vegetation... something about it has a rubbery quality. It's extremely durable... but slows coating IMHO... I usually strip my Busse Users too. And I also lay the edge back a bit... not quite as much as you did but to a degree I find exceptable as an all purpose working edge that can slice, skin, or chop as needed... Cool Mod... I think Busse Knives are some of the best in the world... adding that little something extra to make it fit your needs exactly will only make you appreciate their overall quality even more.
Oh yeah... as a side note... in the future... KS-3 stripper from Kleen Strip will take the coating off a knife in 15 minutes... usually on a Busse it's bead blasted under there anyway... Just in case you can't make it to the Bead Blaster on a day you want to strip a knife coating. You can buy KS-3 at Home Depot.
Nice peice. I have convexed the edges of my RC6 and RC4. I find it gives a better edge and cutting performance.
dude that knife will survive any winter coarse on any continent on the planet.i have the fat .320 ASH and wish i had a skinny instead.
also i love it when people actually use something that is like a high powered sports car of the knife world and not put it to waste in a safe.why garage a porch 911.
secondly its great that you touched it up however best suits you.these knives come from the factory with so much potential but usually need a liitle customization to fit that users individual needs so whatever works.i've also seen people grind down that talon hole area at the bottom of the handle where it meets your pinky.when you use it extensively you may find it to rub on your pinky too much if doing any light chopping.
i'm thinking about doing the same thing.i've seen it and it actually looks good and not like a cutlery amputee or deformed mutant knife.its somewhere between the 1st and 3rd page on the busse forum here right now i think or maybe in the busse for sale thread.
its a huge improvement in functionality imo and aesthetically as well
That convex edge looks awesome! Good for you guys for making it just the way you want it. I love that Simon uses inexpensive tools to get the job done. Takes skill for sure!
Looks great. I think most Busse's need something like this to really be users. I immediately sanded all the harsh bumps off my battle mistress' handle. And the edge is nice and convex now. I still haven't removed the coating though. Mostly because I'm still trying to decide if I want to remove the scales and rehandle it.
Two questions.
1. What is controversial about that cardboard polishing wheel? I've seen that done before, and its a prooven idea.
2. Sigguy, why the hell aren't you wearing a mask? Steel dust is not good for ya bro.
Kevin, its cool to see the difference from the before photos...
thanks for the kind comments guys!
Andy, the cardboard wheels caused a bit of drama in maintenece, tinkering and embellishment a while back...
and i wear a mask most of the time, but i guess i simply forgot since i was constantly chatting with kevin...:o
