What gets me is the blind loyalty to the cartridge because of it's history. If you look at ANY ballistic test the +p 9mm meets or in most cases exceeds the .45ACP. Usually with twice the capacity.
with today's hollowpoint bullet designs, all service caliber handgun rounds suck equally. There is virtually no difference in stopping power between any 9mm, 40, or 45: they all punch little holes. That being said, the 45ACP will never go away as, like the 1911, it's proponents are driven more by nostalga than rational thought.
As for the 45GAP, i can have 8rds of it in a glock 19 size package, or i can have a glock 19 with 15 rounds of 9mm. Easy choice. Stopping someone with a handgun relies on the projectile destroying the CNS or impacting a vital structure causing enough blood loss to incapacitate. The solution is more holes.
I sort of confused here, but can you clear up how you think hollow points make all bullets suck. What do you want to shoot FMJ bullets, do you think those would make bigger holes.
correct, pistols poke little holes. Rifles tear shit up. All pistols suck equally well at killing people.
Hollowpoints level the playing feild even more.
Everyone here understands rifles are superior to handguns in the stopping department.
Ballistics, gel, penetration tests, blah, blah, blah............
None of that means squat.
The only thing that matters is how often the particular cartridge with a particular bullet puts down the bad guy/girl on the street in the quickest manner.
That is the only true test of any cartridge designed for self defense.
If all that stuff meant anything, and if all cartridges fired from a handgun were equally worthless then the GAP would be just as good as anything else.
For those of you looking at the numbers, when a 230 grain bullet with the same HP design is pushed at the same velocity it does not matter from whence it came. It will have the same performance and will give the same results.
If the GAP performs well on the streets it will be here for a long time to come.
The ACP will never go away since it is a proven performer in a proven package that exists in too great a number to be cast to the side.
Big and slow or fast and light? It doesn't really matter that much when you have good shot placement because both will work in normal situations.
Having actually used both a .45 acp and a 9mm in life or death situations...
