- Dec 6, 2006
As it pertains to a quenching medium for steel.
#1. Low price
#2. Great availability
#3. High flash point
#4. High smoke point
#5. No vapor jacket or vapor stage
#6. High speed at the onset of the quench
#7. Finishes slow
#8. High stability compared to other common vegetable oils
#9. Less sensitive to temperature variation than are the parrafinic oils
#10. Non toxic and relatively safe to use
Can you think of any others?
Quote:
Overall, the cooling properties of the vegetable oils were comparable to each other and it is notable that only convective cooling was obtained with no extended vapor blanket cooling (film-boiling). This cooling profile shows that vegetable oils would not require a cooling rate accelerator and would be acceptable even for difficult to harden, crack-sensitive carbon steels. VEGETABLE OIL QUENCHANTS: CALCULATION AND COMPARISON OF THE COOLING PROPERTIES OF A SERIES
OF VEGETABLE OILS
Just to be fair, could you please play the devil's advocate let us know what the disadvantages of canola oil are.
I often find without discussing the negatives of a certain product or procedure, progress will never be made and stagnation occurs.
