I think the reason canola is preferred over some of the other vegetable oils is mainly just it's high stability. It doesn't oxidize as fast and lasts longer than most of the others.
Mike, I think for 01 or L6, if you used an interrupted quench and got it straight into the temper,... it would probably be O.K.
Yeah Mike? I'm much more inventive than you, my friend. I clay coated a fully sharpened O1 blade, heated it to bright yellow and quenched in a bucket of ice water.For fun i tried a piece of O-1 into brine.....
Tai,
What is the indicator as to when to pull the 01 out of the oil for the interrupted quench when using canola?
... and I ain't kiddin' brother.
HAHAHA! How did that turn out? Explosive? Did you check the grain? Was it the size of peas? LOL!Yeah Mike? I'm much more inventive than you, my friend. I clay coated a fully sharpened O1 blade, heated it to bright yellow and quenched in a bucket of ice water.
1095 can be particularly difficult to achieve full martensite conversion. In fact, there are some very low alloy, on the high side of carbon, melts of 1095 where the nose goes all the way over and touches the left hand side of the graph. Meaning, no matter how quickly you quench it, there will be some pearlite. An instantaneous quench, from 1475, to room temp in one nano second wouldn't be fast enough for a blade made from that batch, and it would still meet the specifications for 1095. So, I guess your "best bet" would be to use a cold brine with violent agitation, (just kidding).
My point being, as in many things in life, I think there is not a right or wrong answer, there is a large grey area with a lot of legitimate opinions. According to the literature, it is quite possible to achieve good results with most water quench steels with canola. And experience has shown us that you can still botch a quench in Parks and even water. Your heat going into quench, your agitation during quench, your edge geometry, the batch of steel you're working with and even your grain size will affect your blade's reaction to whatever quenching medium you're using.
I think it is time for the people around here using one oil or the other to stop looking down their nose at people who quench in something different than they do. If you change from one to the other and got better results, it is very likely that the oil you changed to was better suited to your particular process than just a weakness of the oil you were using. Let me say that again: if you used to use canola and switched to Parks and saw improvements, that does not necessarily mean there was a problem with the canola, it could simply mean your overall technique responds better to Parks. And there is nothing wrong with that.
I think that the negativity and sarcasm that frequently surrounds this subject is misplaced.
