Hi guys and gals, just got my first cast iron skillet, it says it is pre-seasoned with vegetable oil, but I am reluctant to use it because I am not totally trusting the pre-seasoning. Should I scrub it out and re season it (thinking mineral oil maybe, because it doesn't go rancid) or just heat it up and go for it?
wash and dry and use the effing thing
if you don't like the results, google, strip, and season. it's cast iron.
i cannot believe how many people don't trust the "from factory", mod stuff, and waste time.
use it. you have nothing to lose.
Just got a few pictures of my father's most recent cast iron purchase and restoration.
Before:
After:
I have a bit of a follow-up to this post.
Here's the old stove in my folk's place plumbed in and fired up.
Best thing you can ever do for your cast iron is to use flaxseed oil (raw linseed oil) on it. (NOT BLO) This is a slow hardening oil that does not go rancid and makes a "real" non stick coating.
For twenty or so years I used Crisco or veg oil and it worked but nothing like using linseed oil. You start wiping down your cast iron with that and in a short matter of time you will have a non stick coating better then any of those teflon pans out there.
Also never wash your pans with soap, just wipe out with hot water. Use only soft non scratch scrubbies on your pans if you need to scrub them. Use wood, or bamboo utensils when cooking and never metal.
Follow these simple things and you should be good to go.
Greebe
I picked up a round ten inch griddle and a long rectangular one from Lodge. I have yet to use them, but it shall be very soon, probably this weekend.
But, being a metal junkie, I had to improve the finish on the round unit. I broke out the angle grinder and had at it. Too many "Tool Time" episodes from back when have spoiled me. :adoration:
I did that to several of my Lodge cast iron skillets nearly 10 years ago. Man it made a big difference. The old Griswalds were ground like this, but Lodge is lazy and leaves them as cast.
