- Feb 1, 2012
Charlie brought a surprise to the 2014 G.E.C. Rendezvous...
The Skunk Barlow!
More accurately, GEC surprised Charlie with skunk barlows at the Rendezvous.
~ P.
The Skunk Barlow!
Wonder if a run of acrylic TCs would ever be in the cards?
That would be boss!
:thumbup:
Osage Orange Wood handles would be the bomb!
Yep - or Ironwood Burl. :thumbup:![]()
jon_slider email 08/11/2014 said:some notes on gec charlow production
the original estimate that only 9 ebony single spear long pulls were produced in 2013 is updated by the GEC production schedule, which says 25 were made. I recall that Gec at that time began producing a run of Ebony Boys knives, that did not use Charlies Ebony. I suspect that the Gec sourced ebony on the Boys knives was also used for some of the 25 Ebony Charlows.
http://greateasterncutlery.net/blog/wp-content/uploads/2014/05/2013-PRODUCTION-TOTALS.pdf
The walnut charlows btw, are stabilized. That means acrylic impregnated wood treatment, because walnut is light and porous, density of 40 lbs. The Acrylic density is 72. That makes the wood impervious to liquids since its soaked in hard plastic. Acrylic is food safe and is used. Stabilized wood is used on high end knives because the material won't shrink or expand, and takes a high polish. However, acrylic does not tolerate boiling water, and it is flammable.
Thanks, P, for the clarification. Got any more inside info on these?
Some insight from Jon today on the first run ebony spears, and the walnut wood:
jon_slider said:he original estimate that only 9 ebony single spear long pulls were produced in 2013 is updated by the GEC production schedule, which says 25 were made.
Good stuff!!
I believe there were those few at the end of 2012, and the run with the pile-side pens was in 2013. Might be wrong, though. Can you check that beautiful harlequin one?
Every PPP I've seen was a 2012.
Jon and I discussed whether or not the 3rd Cut Stag is stabilized. I have a hunch that it is, but no hard evidence. It might also just have a CA finish on the outside. I think there is definitely some sort of sealant/coating on them because the stuff is extremely porous.
:thumbup:
That was the First Run, the Premier of the #15 Barlow Pattern. All subsequent runs are variations on (or returns to) the pattern; only the first is the Premier, and warrants the PPP.
~ P.
