In a previous post I talked about the wear my Elmax 566 took when cutting fiberglass landscapers fabric. After sharpening, while testing the edge using phone book paper the edge "stuck" in a couple of places. Looking at it under a 10x loupe I could see, just barely, several hard wear spots that looked similar to a chip but I knew were not.
I'm really fussy about the edge of my knives, not all of them, so prior to another run on the Lansky I used the fine diamond hone to carefully smooth the edge by running the hone over the edge until it was smooth and wear free.
It took perhaps an hour on the Lansky to sharpen it using the medium/fine diamond, black arkansas, yellow then blue ceramic hones followed by black/green compound on my strop...edge came out glistening and sharper than I'd ever achieved before. Shaved arm hair like a laser, same to phone book paper.
It was worth the effort both as a learning experience and higher level of edge sharpness for me.
PS: I finished cutting the landscape fabric using utility knife blades...used one and threw it out...you could see the wear on it much more easily...almost like cutting carpet or a roll of paper.
Point is: If you feel your knife's edge has any annoying nicks, etc. don't be afraid to hone the edge smooth and start over. You won't remove enough metal to matter, unless it is a large chip/nick then I suppose you have no choice either unless you can live with it...I could not.
