Thanks DogoWar
Per hitting the laminate top, I've done it with each of the other knives at least more than once. Not one has chipped or even bent the edge. I don't use the laminate as a cutting board, sometimes the knife just goes through the fruit quickly and hits the top. It left no visible mark on the laminate. So, it ain't knife abuse and certainlly doesn't explain why the tip decided to run away
Per microchips happening until you remove the initial edge. Great theory, but I've never seen it in practice, nor heard a custom knifemaker say it is "normal". If the theory is correct, I believe it means the cutler let the grinder get the edge too hot. This is a production error, that I wouldn't expect an experienced cutler to do. I did have a Benchmade that had obvious discoloring on the tip from getting too hot during grinding. This was in the late 90s, I called them and they said it was rare, maybe not a problem, but replaced the blade for free. I haven't seen it on any knife since.
I have two S30V blades other than this one, Buck Mayo and Buck Hartsook. Both have the Bos heat-treat and his mark on the blade. The Mayo I bought well used (the tip was dull, but not chipped) and it had no chips and didn't get any in the year I've abused it. I've always wondered why Buck has their $25 Hartsook done by Paul Bos. Maybe its because S30V needs some special attention? In the US, does Spyderco do their own heat treat or is it subcontracted? That may explain why only the US made spdyercos seem to have a chipping problem, since other firms don't have it for s30V.
Confederate, at the discount price of 120, I looked at the Tmag and wouldn't buy it because it doesn't lock. However, for 50 it's a great buy. The magnets have some force but not much. A fellow pool player said the knife would get me arrested since you can readily flick it open it qualifies as a weapon under the gravity/centripital force part of the switchblade statue. The waiter, a police cadet, agreed. My blade got a little loose, so I had to locktite it. I did tighten the pivot a little extra, and it doesn't flick open as readily and it gives more resitance when closing. Overall it makes it a better user if you keep the pivot tighter. Once you get used to the magnet, you can easily keep it from closing on your hand, even if you don't put your finger in the choil.
