- Dec 5, 2008
Let me give you an idea of what you can get done with a little folding saw...
I have never used a small saw like that.
I have used this one:
http://www.rei.com/product/404040
Reason I was asking about how thick is I think the length of the saw blade, or the thickness of the wood on whether one is better than the other.
Also technique plays a part.
Saw was faster for me on a lot but not all.
Thicker stuff was easier with hatchet due to limitations of blade size on saw.
Hatchet easier to fell with because the blade doesn't get pinched.
Dawsonbob, Man I hear you on the chopper and the older guy club. My bad shoulders prefer the saw 100 to 1. I have several saw that make childs play of 4 inch or smaller limbs and works almost as well on 6 inchers. As some of these guys age, they will see what you mean.
I gotta try that Kershaw saw too. I have heard that the SOG saw is decent as well, I have not tried that one.
They are my number one piece of out gear, Give me that and my SAK and I will get through anything.:thumbup:
already there but I prefer Icy Hot. there's still alot of back and forth motion regardless with a folding saw, it can definately be a workout. Depends what I'm feeling like at the time, if a sustained constant grinding sensation or occasional shock would be easier to get over.I hear you, Jim. These young guys will learn what we old, broken down guys already know.
There'll come a time that all these young whippersnappers are going to say "Oh, now I get it," as they're rubbing BenGay into tortured muscles.
A lot depends on what kind of wood you have in what location.
I think so too. IMO something like Elm is faster sawed than chopped due to the grain pattern.
Something like maple faster for me to chop depending on the diameter.
Say something 15' long and 4" diameter on the thick end I'll set on the thick end and then chop around it one time with the hatchet and crack it then keep doing that and I can get thru it faster that way than sawing.
4" to 6" better to set it on something and saw it because the hatchet blade will not penetrate deep enough when you chop all the way around.
Over 6" was really too big for my Sven.
The 8" folding sound really good. I may have to check one out. They're cheap relatively speaking.
Out here at least where I usually hike we're dealing mostly with pine, cottonwoods and oak; maybe not as tough as the stuff you deal with (although the oak can be hard, no matter where you are).
When I had to build my cabins the swede saw was an absolute Godsend. But the large frame makes em hard to carry. That is why I've gone to the pocket chainsaw and fitting it up into a framesaw.
Saws are much quicker maost of the time, especialy if the diameter gets larger such as 8" plus. The chopper then gets its workout doing all the limbing and peeling etc.
The pocket chainsaw is much more compact than most all of these folding saws and will cut more agressively as well as handling larger material. Which I find to be a real plus.
check out the Wyoming Saw if you don't know what it is, I think this little saw fixes alot of the areas where folding saws fall short. The blade is easily replacable and you can find em at any hardware store, and switch it out with a thumbscrew for a bone or metal blade.
I like that saw too, seems like they even make different blade lengths.
The Laplander is a good folder too. I think they make the blade for the Kershaw folder.
What do you guys use the saws on your SAK for?
